Evo X Logging
Old Mar 9, 2010 | 07:31 AM
  #931
tsitalon1's Avatar
I must of missed something is 2.7 beta 5 still the most current?
Old Mar 9, 2010 | 07:38 AM
  #932
_Speedy_'s Avatar
Originally Posted by xPRimNT
The log skipping issue has been a huge hurdle for me. It happens with ALL THREE of my Vista computers, but doesn't happen with my POS old XP laptop. It's been enough of a pain that I've switched completely to the standalone logging through the Tactrix cable.
Disable multi-threading from the logging menu is off by default on my installation of Evoscan, so that wasn't my issue. I actually had a similiar problem on my new Toshiba laptop at WOT, it turns out, its enough to set the Hard Drive motion/drop protection into action, turn it off in the settings. or put your laptop on a jacket on your passenger seat. better yet, get a passenger to hold your laptop. It actually goes to show how hard driving in hard suspension EVO is on a laptop, lol. I heard that Evoscan v2.7 beta has 30 second log file buffering now, but if you are on a bumpy road or at WOT, things are still not going to be happy with your laptop spinning Hard Drive. I've also noticed the standalone evoscan unit can datalog with op2.0 cable very well with no skipping issues, probably because the sdcard has no moving parts, unlike a laptop which has spinning hdds. Laptops are ok on a dyno, because theres no real inertia
Old Mar 9, 2010 | 07:42 AM
  #933
_Speedy_'s Avatar
I'm on about v2.7 beta 20. I think its only available to those on his msn messenger that give him feedback daily.
Old Mar 9, 2010 | 08:08 AM
  #934
tsitalon1's Avatar
Ahh...OK.
I'll wait till it's "released"
Old Mar 9, 2010 | 08:37 AM
  #935
tonyboy's Avatar
hmmm beta 20 huh..yea i'll wait for that one to be released too..
Old Mar 9, 2010 | 01:37 PM
  #936
xPRimNT's Avatar
That's actually a very likely possibility...
I have multithreading off, but it's entirely possible that the sudden motion protection is causing issues. I'll give it a try, thanks!
Old Mar 10, 2010 | 04:56 AM
  #937
_Speedy_'s Avatar
YEah, EvoX map tracer editor with reflasher all in one tool... sweet.
https://www.evolutionm.net/forums/8078837-post1231.html
Old Mar 12, 2010 | 06:17 AM
  #938
Fourdoor's Avatar
Originally Posted by Fourdoor
Temperature problems in EVOscan.
In the morning I will log x with no modifiers from cold (what ever my thermometer reads will be my starting data point) to fully warmed up (This would peak at 176 idling in an EVO XIII... is it the same with the 4b11?) and use those data points to try and determine what the real formula should be for deg F.
I got the following results:
start temp 44F
End Temp max aprox 178 then cycle from 172 to 176
F temp . . . . . . x (Unknown temp)
44 . . . . . . . . . . . . . . .51
176 . . . . . . . . . . . . . 126
F =(m*X)+b
Where x is the unknown temp m is slope and b is the intercept
F temp . . x (Unknown temp) . . . . . . . . . . . . . . equation
44 . . . . . . . . . . 51 . . . . . . . . . . . . . . . . 44 = 51m + b => 44-51m = b
176 . . . . . . . . 126 . . . . . . . . . . . . . . . . 176 = 126m + b => 176-126m = b
44-51m = 176-126m => -132 = -75m => -132/-75 = m => m = 1.76
so with m defined we can calculate b
F = m*x +b => 44 = 1.76*51 + b => 44 = 89.76 + b => b = -45.76
So conversion of x to F is F = 1.76*x -45.76... so the "size" of each deg (1.76) is very close to the "size" of a deg C (1.8) when compared to deg F. Assuming they are actually the same, and adjusting the intecpt as well to get correct results we end up with a final formula of:
F = (1.8*x)-50
For the speed formula I was able to verify that kph = 2*x, so the correct formula for mph is mph = kph / 1.609344 and the given formula in EVOscan for kph is x*2 then the formula for mph should be x*2/1.609344. This breaks down to mph = x*1.24274239.... so from now on I will be using
mph = x*1.243
Later,
Keith
Old Mar 12, 2010 | 02:05 PM
  #939
_Speedy_'s Avatar
good work.
don't need the brackets (multiplication always takes effect before additions),
also don't you think its a major coincidence that its basically the universal formula of F = 1.8 × C + 32
x-40 is the universal formula for Mitsubishi DegC
which is effectively: 1.8 * (x-40) + 32 <--- try that one, let us know if it works.
Old Mar 12, 2010 | 07:40 PM
  #940
Fourdoor's Avatar
good work.
First thing I checked That is why I concluded that the standard C = X-40 is incorrect.
If you use 1.8*(x-40)+32 with the data I started off with of 51 for the logged value of x at cold start after sitting all night with ambient temperature of 42F you end up as follows:
1.8*(51-40)+32 => 1.8*11 + 32 => 19.8 + 32 => 51.8 The actual temperature was 44F by the thermometer in the car, 42F by my outside house thermometer (more accurate of the two) so it is off by a full 10 deg. At the other end of the spectrum we have 126 for the value of x
1.8*(126-40)+32 => 1.8*86 +32 => 154.8 + 32 => 186.8 The actual temperature at idle is right around 176F, so once again off by a full 10 deg high.
I don't know who came up with the C=x-40... but it is not correct at least on my car. I can do the math for any of my non-american brothers out there that want the correct value to calculate temp in deg C if anyone requests it
Keith
Old Mar 13, 2010 | 12:45 AM
  #941
tephra's Avatar
x-40 is correct.
what memory location+romid are you logging?
Old Mar 13, 2010 | 03:03 AM
  #942
Fourdoor's Avatar
Originally Posted by tephra
x-40 is correct.
23808653 on ROM ID 55590006. And yes, C=x-40 is specified in the code for this ROM ID.... I think my temp sensor is off by 10 F (5.6 C)
So, if it is a temperature sensor miss calibration on my car so that the ECU thinks my car is 10 F warmer than it is my fans will kick on early, and kick into high speed early... are there any protective functions that will kick in early? The fans are not a real problem, but I wouldn't want the car to go into limp mode of some kind when it is not actually over heating.
Hey Tephra, in the 55590006 code is memory location 23804573 the LTFT idle or LTFT cruise?
And last but not least... is there any way to get ride of this F#$%ing P0139 for 55590006?
I was talking with Hamish tonight, and we were wondering about the Manifold Air Temp. The memory location he has is 2380867A, but that does not work for 55590006... I get a constant -40 indicating that the x value is a constant zero.
We also talked about the next things that it would be useful to log would be injector pulse width and duty cycle.
Just throwing around ideas here
Thanks,
Keith
Old Mar 13, 2010 | 04:23 AM
  #943
tephra's Avatar
1) leave your car overnight, in the morning compare the temp sensor on the HUD to the logged item - as long as your car isn't/wasn't in the sun they should be the same - within 1-2C
2) not sure on the LTFT, look at the addresses for MUT0C/0D/0E (from memory are low/mid/high OR idle/cruise/high)
3) P0139 is slowly being worked on
4) MAT is usually +5bytes from MUT11
5) IPW = MUT21 + 20
6) IDC you can calculate from IPW*RPM/1200
Old Mar 13, 2010 | 08:02 AM
  #944
Deepseadiver's Avatar
I have just read the first 30 pages and will try and read the rest in the morning. Yes I did read the illistrated "How To"
I have a few noob questions about getting mode 23 working. I down loaded the newest version of EVO SCAN today, and have the 2.0 cable, and ECU FLASH. my ROMID is 52680015.
I am pretty sure I can work my way through this, but what are the Attached Files for in the first post? Are they for a different logger?
I got to this step and was stuck.
Copy the XML from step 5 and paste it BEFORE </rom>
I found it and opened the xxxxx15 file, but could not copy or paste or edit the three lines of text that needed to be inserted. I know now that I needed to open the file with note pad and make the addition. Then do I just hit save when I am in note pad and it will save in the right place and the right type of file?
Thanks for all the hard work that went into this.
Old Mar 13, 2010 | 11:24 AM
  #945
Fourdoor's Avatar
Yup, you edit the file in notepad and save it. It will save in the same file format and file name that it had to start with. BEFORE doing this make a copy of the original and save it in a separate location just in case you screw up your edit you have a clean backup.
Keith
