Evo X Logging
Old Mar 15, 2010 | 02:17 AM
  #961
SiC's Avatar
SiC
Yeah, I thought the same thing too so I decided to download it and install it again. I was able to install it without any problems and it isn't an RAR archieved file. I have no idea why you are using WinRAR, I suggest uninstalling WinRAR and redownloading/installing ECUFlash again.
Old Mar 15, 2010 | 02:36 AM
  #962
Deepseadiver's Avatar
Originally Posted by tephra
why do u need winrar?
try downloading ecuflash again... maybe it got corrupted...
I tried again and got the same thing. I thought it might be a zip file thats why I got WIN RAR. It downloads really fast. l would think it would take longer. Do I need to change something on my net book? Or download it to a different location?
I have the older version on my laptop. but it is old and solw and the battery is shot, but it works. So I think I installed mode23 with my laptop, and I thought I would just use my net book to make some logs, but the net book dose not have the driver for the openport 2.0 cable. Where can I get the driver just for the 2.0 cable?
Old Mar 20, 2010 | 10:11 AM
  #963
FTY Motorsports's Avatar
when is the new evoscan gonna be released
Old Mar 20, 2010 | 10:24 AM
  #964
stokEd's Avatar
Soon, I hope. And from what the beta testers are saying, it shouldn't be long: https://www.evolutionm.net/forums/ec...ml#post8109420
Old Mar 26, 2010 | 05:49 PM
  #965
Mellon Racing's Avatar
maybe this has already been explained but while looking at something else I noticed what I thought was a duplicate in the first post but the address's are different???
55580005
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f107" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad43" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad4a" type="1D" scaling="Hex16"/>
55580005
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f10b" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ad4b" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" type="1D" address="0x8ad52" scaling="Hex16"/>
Old Mar 26, 2010 | 11:50 PM
  #966
Fourdoor's Avatar
~2ms @ idle
20ms @ pk boost
15ms @ redline
93oct/stock injectors
Cool, on E-85 I am seeing
2.6ms at idle
25 ms at 23.5 psi of boost
18.6ms at redline around 16 psi of boost.
Looks about right
Now what is wrong with my IDC calculation? I am getting way high numbers for IDC... at idle my IDC is reading 73% !!!
I used the formula [IPW]*3.90625*x/1200 where "x" is the address for RPM.
The interesting thing is that my actual RPM calculation uses 31.25*x and I notice that the IDC formulas that use 3.09625 have RPM values that also use 3.09625.
Here is the strangest part. When I plug the above formula [IPW]*3.90625*x/1200 into a spread sheet and input my data for IPW and RPM I get correct output (about 90% duty cycle at peak boost).... but using that same formula in the "function" block for my IDC calculation in EVOscan I get jacked up results that are way too high (3,210% instead of 90%)
I am soooo confused right now!
Keith
Old Mar 26, 2010 | 11:59 PM
  #967
tephra's Avatar
depends what RPM you are logging:
2byte formula = x*1000/256
1byte formula = x*31.25
Old Mar 27, 2010 | 12:16 AM
  #968
Fourdoor's Avatar
Well, my RPM logging appears to be 1 byte. But for my IDC calculation it appears to be 2 byte. If I put everything in the IDC logging to match 1 byte should that correct the problem?
Now that I have a functional MUT Table perhaps I can actually understand the difference between 1 byte and 2 byte values and how they are used... do you have a tutorial on that type of thing somewhere in here?
Also, I can't find the thread dealing with making tuning not affected by LTFT's... I think that is what it was, and I remember implementing the changes in my ROM code... would that be why my LTFT's are a constant 12.5?
Thanks,
Keith
Old Mar 27, 2010 | 12:19 AM
  #969
tephra's Avatar
if the memory address for IDC is the same as RPM, and your RPM formula has 31.25*x, then use 31.25 instead of 3.90625
https://www.evolutionm.net/forums/ev...t-fueling.html
Old Mar 29, 2010 | 03:00 AM
  #970
livevil's Avatar
wow ! . lots of good reading here ... my eyes are burning ,
Old Mar 29, 2010 | 06:14 AM
  #971
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by acamus
MUT initialization in CT9A returns 4 bytes:
0x00 0x55 0xEF 0x85
MUT init reply bytes' locations in 53040010:
0000E300 ECHO_REPLY 0x00 - presumably
00040F84 Sync word 0x55
00040FC4 KeyWord #1 0xEF
00041034 KeyWord #2 0x85
Now who will be the first to sort/try it out?
I bet on tephra, but hamish is my second candidate
I had to do it myself :P
I have gone thru MUT communication again today.
I have a suspicion that we are unable to connect via MUT due to
ECU_OPTIONS_3 & 0x01 (bit 0) aka MUT Enable bit.
Is somebody willing to test changed ECU_OPTIONS_3 and logging via MUT EFI?
I am still awaiting ECU from HB Speed
Before you all jump on me:
Originally Posted by gunzo
Originally Posted by Hiboost
ECU Options -> ECU Options Set #3 -> bit.0: Lean Spool Off/On
Might be worth seeing if it will improve the situation, although you will want the LTFT disable to make it more predictable.
there is no such function on the 2008 ECU .. don't waste the effort
Old Mar 30, 2010 | 04:09 PM
  #972
xPRimNT's Avatar
Hey all,
I was wondering if any of you EvoScan beta testers have been able to get the Evo X ECU Reset to work.
I'd love to have this feature, especially for dialling in fuel trims. The Canadian ECUs have an anti-tamper shield on them, so if I ever go to help a local person out with trims, we either need to disconnect the battery and wait, or dremel off the shield so that we can pull the harnesses out.
Or, is there a manual command that we can send? ECU gods?
Old Mar 30, 2010 | 07:58 PM
  #973
NZEvox's Avatar
Tried it
Sorry does not work
Old Mar 30, 2010 | 10:53 PM
  #974
acamus's Avatar
What cable have you been using for logging?
If you are in posession of 1.3 can you repeat the test?
Otherwise I have to wait for the ecu.
Old Mar 31, 2010 | 02:42 AM
  #975
NZEvox's Avatar
Using a 2 . will try to get hold of a 1.3 and let you know
