Evo X Logging
Old Mar 31, 2010, 02:19 PM
  #976
SiC
SiC's Avatar
Originally Posted by xPRimNT
Hey all,
I was wondering if any of you EvoScan beta testers have been able to get the Evo X ECU Reset to work.
I'd love to have this feature, especially for dialling in fuel trims. The Canadian ECUs have an anti-tamper shield on them, so if I ever go to help a local person out with trims, we either need to disconnect the battery and wait, or dremel off the shield so that we can pull the harnesses out.
Or, is there a manual command that we can send? ECU gods?
Nope, the reset ECU feature doesn't work for the EvoX in Evoscan yet.
Old Mar 31, 2010, 09:26 PM
  #977
xPRimNT's Avatar
Too bad, it would be nice to have!
Old Apr 6, 2010, 07:18 PM
  #978
Piper747's Avatar
I am trying to log MAT. I have tried logging MUT 11 + 5 bytes as suggested earlier. MUT 11 for me looks to be 808661, so I logged 23808666 and I get -40 constantly. MUT 11 seems to be giving me a proper value for MAF temp. I am ROM 53600010. Any thoughts?
Old Apr 18, 2010, 01:25 AM
  #979
Silver Sponsor
evoscan's Avatar
Hey Dudes, whats up... i'm back to help you guys out. A lot of new stuff coming out this year for EvoScan and EvoScan Standalone Unit. -subscribed.
yeah I have attempted to add the code for ecu reset, but it was just a guess, I will need an EvoX connected to MUTIII unit to get this finished.
Old May 2, 2010, 05:00 PM
  #980
Ah10's Avatar
Those are both max values for fuel trims, either your trims/scaling are really screwed up or you must be logging the wrong address.
Your LTFT idle should be 23804573 (MUT0C) and LTFT cruise should be 23804575 (MUT0D).
STFT should be 238088B0 (MUT0F).
The formula for both LTFT & STFT is (0.1953125*x)-25
Hi Sic, does this apply to romid 55570005?
Old May 2, 2010, 05:11 PM
  #981
Ah10's Avatar
and after reading 65pages, my eyes are burning!
my romid is 55570005, 2010 GSR
am i doing it right?
Old May 8, 2010, 05:28 PM
  #982
Excalibur's Avatar
Is there a full list of formulas for all the different values such as the LTFT and STFT for example?
Old May 8, 2010, 05:33 PM
  #983
tephra's Avatar
you can use the config files at the start as a reference...
Most temps are x-40
Trims are (x*0.1953125) - 25
Old May 8, 2010, 05:52 PM
  #984
Keepster13's Avatar
head:wall
Cool
Old May 8, 2010, 06:29 PM
  #985
tephra's Avatar
got it?
Old May 8, 2010, 06:40 PM
  #986
Excalibur's Avatar
Most temps are x-40
Ohhhh, listed under the function column correct? lol.
Old May 8, 2010, 06:52 PM
  #987
tephra's Avatar
thats RPN thou... but you should be able to convert it easy
Old May 8, 2010, 07:02 PM
  #988
Excalibur's Avatar
Not good with the acronyms all the way. RPN?
Old May 8, 2010, 07:17 PM
  #989
tephra's Avatar
reverse polish notation
ie we are used to seeing x = (y + 5) / 2
in rpn it would be
x=y,5,+,2,/
Old May 9, 2010, 03:19 PM
  #990
Keepster13's Avatar
I've run into a little problem. I seem to have a hunted computer.
I can see those lines in IE but not notepad to edit them and fix or delete them. I unistall and delete everything than reinstaled. Still get the same thing. Also for the domode #1 it comes up with 17 not 05. I know they shouldnt be in the evo10base file. I want to remove them and fix it all..but.. I can't.. edit them.. Anythoughts?
Quick Reply: Evo X Logging
