Evo X Logging
#106
Try uninstalling ECUFlash and remove all the Tactrix drivers from the Add/Remove Programs in control panel. Reinstall ECUFlash and plug in the OP2 and let the system install the drivers for it. Then try running Mode23 again.
#108
It does not integrate wideband a/f meters yet. I think the plan is to integrate this logger's functionality into evoscan so we can do wideband with evoscan (plus the other evoscan features).
Tephra, this logger is working great!! Thanks so much. I'm going to try to log again with speed in mph. I believe this is the right formula:
Speed:0x8087e7:1:x,2,*,0.62137,*:5
#110
Boost:your mut address:2:x,4,/,0.19347,*,your barometer reading,-,0.0689476,*:1
I believe tephra put in 14.5 for the barometer reading but you should adjust this to your elevation. If you are right around sea level, you'll be at 14.7, etc.
#112
This if for everyone doing logs right now. What are you using to log A/F? I am about to order one, and was wondering what will work best with Evoscan. I was wanting to get the dashdaq or EvoScan navi display unit. Which one should I order? Thanks!
#113
Not bad for a free mail in tune huh?
Hitting 280 max load (26.5 psi), spooling about 500RPM quicker than stock, and dropping to 220 load by redline. The power must've increased significantly and the knock is much less than stock (1-2 counts). I'll work with you to bring the knock to 0 if you wish
#114
#116
Sorry for jacking the thread
#117
That's correct and if you want bar instead of PSI for you boost it's:
#118
