Evo X Logging
Old Jun 5, 2009 | 11:14 PM
  #121
tephra's Avatar
Originally Posted by nj1266
Does this logger integrate AFR meters? Can we log an LM-1/ZT2 through it?
Not directly.
Wire it into the ECU (rear02) and then you can log it that way.
This is just a stop-gap until EvoScan gets up-to-date.
I've decided to log 2byte RPM - since its more accurate and it doesn't slow anything down... If ppl want the memory address let me know their ROMID
Old Jun 5, 2009 | 11:32 PM
  #122
SiC's Avatar
SiC
Count me in, ROMID 52360018, should be the same as your address
Old Jun 5, 2009 | 11:35 PM
  #123
tephra's Avatar
try this:
RPM:0x80873e:2:x,1000,*,256,/:1
Old Jun 5, 2009 | 11:37 PM
  #124
SiC's Avatar
SiC
try this:
Thanx, I'll test it out
Old Jun 5, 2009 | 11:45 PM
  #125
LaXGSR's Avatar
How about 2 byte rpm for 52680018?
Old Jun 5, 2009 | 11:50 PM
  #126
tephra's Avatar
try RPM:0x808746:2:x,1000,*,256,/:1
Old Jun 6, 2009 | 01:58 AM
  #127
tephra's Avatar
hrmm so I found another ROM with the same Cobb stuff up... So I take it back - cobb.
Where ever this ROM originated (and i have a good idea) they are doing some funky stuff
Old Jun 6, 2009 | 09:09 AM
  #128
LaXGSR's Avatar
Thanks tephra, I'll try this out tonight or tomorrow! So with the revised boost psi formula adjusted for atmospheric pressure, I'm running more boost than I thought was possible. Even my stock map is running higher than I expected. Just to confirm, the 14.5 in the original psi formula should be replaced by local atmospheric pressure?
Old Jun 6, 2009 | 12:21 PM
  #129
Bob_tm's Avatar
Tested on edm Evo with 53040007 rom. Work great!
Old Jun 6, 2009 | 12:41 PM
  #130
xbox4414's Avatar
Running Windows Vista 32bit with SP1....I plug in the OP2, open the program and then Windows says the program stopped working and closes. Any ideas?
Old Jun 6, 2009 | 01:42 PM
  #131
MR. Tim's Avatar
I am missing something here...... My Rom Internal ID is 52680020. It says it inherits 52680015. So i use Tephras 1st config file (config-52680015-52680020,52690019) right?
In ecuflash - what xml do i modify with this data:
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
When i open up the 52680020 xml file, it only has like 18 lines in it, none of which resemble anything like what i am supposed to modify it to look like. Do i modify 52680015 since that is what my rom inherits?
Old Jun 6, 2009 | 05:19 PM
  #132
SiC's Avatar
SiC
You don't modify any lines, you just add those lines before the </rom>
Old Jun 6, 2009 | 05:22 PM
  #133
MR. Tim's Avatar
And i add those lines into my 52680020 xml file right?
Old Jun 6, 2009 | 05:27 PM
  #134
LaXGSR's Avatar
I added mine into the 52680015 xml file in ecuflash since that has the "Misc" section in it. That works great for me.
Old Jun 6, 2009 | 05:28 PM
  #135
LaXGSR's Avatar
I've had this problem if I have the log file open in Excel and then try to run the logger. You don't have the log file open do you? Or perhaps the program doesn't have permission to write to the folder that the .exe is in. On Vista, this can happen if you have the .exe under "Program Files" somewhere. Try putting it on the desktop instead as a test. Otherwise, you may also need to run the .exe as administrator.
Quick Reply: Evo X Logging
