Virtual Dyno Room-Dyno Simulator
#31
I will edit the passenger weight box to allow negative values with the next revision but I really don't think its necessary since I compared a car that weighed 2700 lbs to factory weight cars and had LITTLE difference on the mustang dyno with pre-loading.
#32
Only the driver weight makes a difference with the Mustang dyno sim's. The standard weight is used for Mustang simulation is 3400 lbs with a 175lb driver included. If the driver is lighter or heavier it changes but the base vehicle weight is modal. It has to do with the simulated pre-loading of the Eddy Current dyno's and the fact that almost all Mustang dyno shops stick with one vehicle weight for all Evo customers unless extreme weight reduction has been done. If you want to lower it, just lower the passenger weight below 175 lbs. Trust me, it works well enough lol.
#33
Well, so far it seems to work pretty accurately between the MD dyno results and the street results of the same car on the same day that I logged, 3 cars from 3 MD dynos so far have had the same results on the street vs. the MD dyno. *shrug* Trust me, I dont know how it works but so far its the most consistent thing I could get to work thus far for the MD simulations. Once I see more hard data showing differently I will most certainly update the program to reflect it as much as possible.
Bryan @ GSTMotorsports is going to supply us some MD dyno vs. road dyno data soon so we can have more data to compare. The more data we compile, the more we can dial everything in. The more the merrier in this case!
#35
#38
I think its working ok because Evo 8/9s all are within about 100 lbs of each other (except for some prepared cars). Its still not right though. It would be more correct to multiply the road dyno acceleration whp component times the ratio of MD vehicle weight to actual weight. Then add in the drag whp.
Bryan also said he would do multiple pulls with a wide range of vehicle weights inputted into the dyno software (as well as the vehicles ACTUAL weight)to see how much the numbers vary. He has said that he's seen little difference with large weight changes entered into the dyno but I'd still like to see the results for my own curiosity.
#45
Ok, so no dice yet but all you need to transfer over is the RPM value closest to each 250 RPM increment anywhere between 2750-8000 RPM and the recorded time interval for that RPM. Much faster than copying the ENTIRE log over at least lol. I'll try to work on it. Try the AEM forums and ask if there is a way to output your data into an excel "friendly" file.
