Virtual Dyno Room-Dyno Simulator
#874
First of all i'd like to congratulate you on a great dyno tool, just to add some input i've noticed that you can't get a 4th gear run graph in comparison pull. Also if you switch to metric in the user setting you cannot get a 4th gear graph in either base or comparison mode.
In any case, thanks for this useful tool.
Stefano
#875
JACK check for my post relating this to AEM Logs in the AEM sub forum.
Wouldnt wanna clutter this one, and it might be helpfull for the other aem guys over there...
#876
I'm holding off for now on making changes to VDR since Bbarnhill is creating a newer version of his own that is coming along quite nicely so far. If its going to take a long time I will repair the bugs in VDR 5.71 but I'm more interested in seeing what he can accomplish right now
#878
By the way, here's a quick solution for now: create your own vehicle in the vehicle list, and put in the 3rd gear cell the 4th gear ratio... Obviously, remember that when you select 3rd gear then it calculates power/torque in 4th gear.
#879
Yeah, so you guys know....you can MANUALLY add ANY vehicle specs to the list and create your own description name for it and it will appear in the vehicle dropdown list. Good way to get around any mistakes I have made for now,lol.
Here is where to do it, just select the VEHICLE LIST tab at the bottom of the screen and fill it out for the specs of your vehicle (no matter what it is). If this does in-fact get the Evo X guys by with the 4th gear issue, let me know. Thanks everyone for all of the support. I am definitely NOT a programmer at all and this was my first Excel experience everrrr using google and the HELP section in Excel lol.
#882
#884
Does anyone have a list of the cars with the gear ratios, final drive, frontal area, drag coeff, weight, for all the models you want to see in my program. I need some help putting in vehicles and if someone is willing to put the information into a file that I provide then that part of it will be done. Any takers?
#885
Should be most of what you need already in VDR in the VEHICLE LIST page. No work to really be done. I spent MONTHS compiling that crap haha. If some 1G 2G DSM guys can help us find the info for the Talon/Eclipse/Lasers that would be cool. Gear ratios are easy, its the weights Cd and Frontal Area that will be tricky. If you play around with the Cd and Frontal area values, you'll notice that at least one of them has a very small impact on the results so it doesn't need to be dead on. Besides, most modded cars change their stance and add bumpers,diffusers and such which changes the parameters from OEM anyhow.
