Evoscan 2.5 & Lm-1 issues
Old Jun 19, 2009 | 04:04 AM
vboy425's Avatar
i'm getting frustrated getting Evoscan to work with Lm-1. Logworks log fine. The weird thing is that. some how The serial to Usb adapter i use getting conflict with the tactrix cable. When both cables "tactrix & serial to usb" are plug in, i can't even uses ecuflash to read or write my rom. even when i unplug the tactrix the stupid ecuflash still see the serial to usb adapter as tactrix cable. help
Laptop windows XP
Old Jun 19, 2009 | 04:29 AM
Import Junky's Avatar
I feel your pain. Hopefully you get help on this so I can try again as well. I gave up on this awhile back when I first started lurking into the Ecuflash forum.
Old Jun 19, 2009 | 04:50 AM
EVO8LTW's Avatar
I never got v2.5 to work properly with the LM-1. I switched to using a Zeitronix and the problem was solved.
Old Jun 19, 2009 | 05:35 AM
eTiLiKo's Avatar
You must return to 2.1
Old Jun 19, 2009 | 05:36 AM
vboy425's Avatar
i will give 2.1 a try today. but i really thing it's a software/cable issue thanks
Old Jun 20, 2009 | 12:32 AM
vboy425's Avatar
finally got everything to work. i went the radioshack and got a gigawork usb to serial. i'm happy.
Old Jun 20, 2009 | 01:36 AM
Live4Redline's Avatar
Had the same issue... didn't even try to fix it... just loaded up 2.1 instead.
Old Jun 21, 2009 | 12:10 AM
jimib's Avatar
So 2.5 definitely has a known issue with the lm1? I kind of come and go in the ecuflash world, and everytime I come back everything is changed ha. I dont think I have had much luck datalogging my lm1 since the .98 days or so ha. How can you download older versions of evoscan?
Old Jun 21, 2009 | 01:49 AM
Thats a hard one to answer because its a pay for kinda thing. But if you bought and paid for evo scan and you still have your info, and then play with the download address you might figure it out. Good luck mate.
Old Jun 21, 2009 | 01:26 PM
mt057's Avatar
I use evoscan 2.5 with my lm-1 with no problems.
Old Oct 8, 2009 | 12:42 AM
Danieln's Avatar
Can you please tell me what cables you use for making this working?
I have lm-2 and I want to use it with evoscan 2.6 and I want to know what cables and what connection I must make in order to make this working.
Thanks
Old Oct 8, 2009 | 07:45 PM
mt057's Avatar
The basic tactrix cable will work and then you need a cable that has one serial connection end and one usb connection end. Any brand should work. Make sure not to attempt to log with logworks at the same time. Good luck hope it helps
Old Oct 9, 2009 | 04:40 AM
Danieln's Avatar
Ok mate,
Thanks a lot
I will do that than.....
Evorange
Sep 16, 2019 08:18 PM
EVO8LTW
Dec 2, 2014 03:46 AM
Swinkndan
Nov 17, 2011 06:32 AM
hearnoevo
Sep 14, 2010 08:15 AM
Inprogress
Jun 15, 2008 03:54 PM
Quick Reply: Evoscan 2.5 & Lm-1 issues
