Boost Control tables
please guys can anybody help me by explaining what these tables are???
this is what i get from ecuflash:
1-Baseline WGDC #1
2-Baseline WGDC #3 (BCLS)
3-WGDC correction interval #1
4-WGDC correction interval #2 (BCLS)
5-Min Load for boost control
6-Max total upward WGDC correction Vs TPS
7-MAx wgdc vs coolant temp
8-WGDC limit during fault
9-boost cut load
10-boost cut delay
11-boost control load offset
12-boost desired engine load #1
13-boost desired engine load #3 (BCLS)
14-Turbo Boost error correction
15-BCS RE/DE-activation RPM
16-Boost Control Limiting vehicle speed
I've use the search option but i cant find any post containing all these information. I'm using the 1.40.2178 ECUFLASH version
BTW, the car is an EVO IX ROM ID 88580014 but inherits from 88580013
Thanks in advance all of you!
1-Baseline WGDC #1
9-boost cut load
10-boost cut delay
bcs, boost, control, evo, evolutionm, fault, limit, load, min, redeactiavation, redeactivation, rpm, wgdc
