Reasons why my fuel table would max out at 7.4?
I recently fixed a leak in my stock 9 diverter valve and began to retune the car (FP Red w/1000 cc injectors)
I did my pump gas map first and my AFR's were way lean. 12.7-13:1.... so I richened it up...more...and more....and more. To now where I'm maxed out as far as the EcuFlash is concerned (7.4) value on the fuel table.
Only thing that I can think is that my fuel pump is taking a dump on me. Has anyone experienced this before?
Yeap drop the scaling. I had the same issue when getting my 1450's going. I actually had a scaling and latencies that created good fuel trims - but I couldn't get my fueling correct in the maps. Everhting was too lean with the values at min.
So I went back and dropped the scaling for the injectors. I then fixed my idle trims with MAF scaling and used latencies for cruise trims.
BUT, if everything was working correctly on these injectors and then changed it could be the pump. Have you had everything scaled and tuned and working on these injectors yet?
