MUT Commands Known?
Old Jul 27, 2009, 05:42 PM
Ceddy's Avatar
Has anyone found the 5 deg Timing Adjustment yet?
On my 95 ECU there was a Timing Adjust terminal you would ground.
I connected a switch to it and had a sort of Anti-Lag Button. I could get a couple extra psi with a 2-step.
It might be possible to easily code an Anti-Lag setup by taking over the Timing Adjust routine, change 5 degree to -10 and have the clutch switch turn it on.
Old Jul 27, 2009, 07:57 PM
MattS00's Avatar
Originally Posted by acamus
IDC command to create Actuator structure:
Code:
	auto id;
	id = AddStrucEx(-1,"Actuator",0);
	id = GetStrucIdByName("Actuator");
	AddStrucMember(id,"index_of_actuator_word",	0X0,	0x000400,	-1,	1);
	AddStrucMember(id,"reserved",	0X1,	0x000400,	-1,	1);
	AddStrucMember(id,"bit_mask",	0X2,	0x10000400,	-1,	2);
	return id;
using Alt+Q one can get
Code:
00009C3C 01 FF 04 00 Command_MUT_C0:Actuator <1, h'FF, h'400>   ; DATA XREF: PROCESS_MUT_REQUEST:off_253D8o
00009C40 01 FF 02 00 Command_MUT_C1:Actuator <1, h'FF, h'200>
00009C44 01 FF 00 00 Command_MUT_C2:Actuator <1, h'FF, 0>
00009C48 01 FF 00 00 Command_MUT_C3:Actuator <1, h'FF, 0>
00009C4C 01 FF 00 00 Command_MUT_C4:Actuator <1, h'FF, 0>
00009C50 01 FF 00 10 Command_MUT_C5:Actuator <1, h'FF, h'10>
00009C54 01 FF 00 00 Command_MUT_C6:Actuator <1, h'FF, 0>
00009C58 01 FF 00 04 Command_MUT_C7:Actuator <1, h'FF, 4>
00009C5C 01 FF 00 02 Command_MUT_C8:Actuator <1, h'FF, 2>
00009C60 01 FF 00 01 Command_MUT_C9:Actuator <1, h'FF, 1>
00009C64 00 FF 00 00 Command_MUT_CA:Actuator <0, h'FF, 0>
00009C68 01 FF 00 80 Command_MUT_CB:Actuator <1, h'FF, h'80>
00009C6C 00 FF 20 00 Command_MUT_CC:Actuator <0, h'FF, h'2000>
00009C70 00 FF 10 00 Command_MUT_CD:Actuator <0, h'FF, h'1000>
00009C74 00 FF 08 00 Command_MUT_CE:Actuator <0, h'FF, h'800>
00009C78 00 FF 04 00 Command_MUT_CF:Actuator <0, h'FF, h'400>
00009C7C 00 FF 02 00 Command_MUT_D0:Actuator <0, h'FF, h'200>
00009C80 00 FF 01 00 Command_MUT_D1:Actuator <0, h'FF, h'100>
00009C84 00 FF 00 82 Command_MUT_D2:Actuator <0, h'FF, h'82>
00009C88 00 FF 00 40 Command_MUT_D3:Actuator <0, h'FF, h'40>
00009C8C 00 FF 00 20 Command_MUT_D4:Actuator <0, h'FF, h'20>
00009C90 00 FF 00 10 Command_MUT_D5:Actuator <0, h'FF, h'10>
00009C94 00 FF 00 08 Command_MUT_D6:Actuator <0, h'FF, 8>
00009C98 00 FF 00 04 Command_MUT_D7:Actuator <0, h'FF, 4>
00009C9C 00 FF 00 02 Command_MUT_D8:Actuator <0, h'FF, 2>
Now the mask is applied at word values by index_of_actuator_word:
Code:
RAM:FFFF6FE0 ?? ??       MUT_Command_Actuator_0:.res.b 2         ; DATA XREF: ROM:off_128F4o
RAM:FFFF6FE2 ?? ??       MUT_Command_Actuator_1:.res.b 2         ; DATA XREF: ROM:off_128FCo
corresponding code is
Code:
ROM:000252DE             loc_252DE:                              ; CODE XREF: sub_2515C+17Cj
ROM:000252DE 6A 13                       mov     r1, r10         ; Move Data
ROM:000252E0 9B 70                       mov.w   @(h'E0,pc), r11 ; [000253C4] = h'C0 ; Move Immediate Word Data
ROM:000252E2 3A B8                       sub     r11, r10        ; Subtract Binary
ROM:000252E4 4A 08                       shll2   r10             ; Shift Logical Left 2
ROM:000252E6 DB 3C                       mov.l   @(h'F0,pc), r11 ; [000253D8] = Command_MUT_C0 ; Move Immediate Long Data
ROM:000252E8 3B AC                       add     r10, r11        ; Add binary
ROM:000252EA 85 B1                       mov.w   @(2,r11), r0    ; Move Structure Word Data
ROM:000252EC 61 03                       mov     r0, r1          ; Move Data
ROM:000252EE DB 3A                       mov.l   @(h'E8,pc), r11 ; [000253D8] = Command_MUT_C0 ; Move Immediate Long Data
ROM:000252F0 6C 03                       mov     r0, r12         ; Move Data
ROM:000252F2 60 A3                       mov     r10, r0         ; Move Data
ROM:000252F4 02 BC                       mov.b   @(r0,r11), r2   ; Move Byte Data
ROM:000252F6 62 2C                       extu.b  r2, r2          ; Extend as Unsigned (Byte)
ROM:000252F8 6C CD                       extu.w  r12, r12        ; Extend as Unsigned (Word)
ROM:000252FA 2C C8                       tst     r12, r12        ; Test Logical
ROM:000252FC 8B 01                       bf      loc_25302       ; Branch if False
ROM:000252FE A1 3D                       bra     loc_2557C       ; Branch
ROM:00025300 00 09                       nop                     ; No Operation
ROM:00025302             loc_25302:                              ; CODE XREF: sub_2515C+1A0j
ROM:00025302 62 2D                       extu.w  r2, r2          ; Extend as Unsigned (Word)
ROM:00025304 42 00                       shll    r2              ; Shift Logical Left
ROM:00025306 D0 38                       mov.l   @(h'E0,pc), r0 ; [000253E8] = MUT_Command_Actuator_0 ; Move Immediate Long Data
ROM:00025308 0A 2D                       mov.w   @(r0,r2), r10   ; Move Word Data
ROM:0002530A 2A 1B                       or      r1, r10         ; OR Logical
ROM:0002530C 02 A5                       mov.w   r10, @(r0,r2)   ; Move Word Data
I would like to spread the disassembly effort, so anyone who can read this can help out
So knowing all this MUT_D8 should check if CEL bulb is OK.
How do you know that the function is refering to the CEL? If I understand correctly: the CEL is connected to one pin on the processor, that pin has references a specific location in ram. The answer maybe more obvious, but I'm new to this, and I'm working on a different mitsu than an EVO.
Old Jul 27, 2009, 09:40 PM
acamus's Avatar
Location: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I know you are after VR-4,below the actuators in H8 based ECU also (23810003_EM2428_99_Galant_VR4).
Thank you for the correction, updated the above post. If you follow where the MUT_Command_Actuator_0 & 0x02 is checked, you will find MUT_9A & 0x80, but Bez has found that MUT_9A & 0x8 = CEL, so I have overlooked the 0 at the end. Sorry for the confusion.
Code:
00012DE4                 Actuator <1, 0xFF, 0>
00012DE8                 Actuator <1, 0xFF, 0>
00012DEC                 Actuator <1, 0xFF, 0>
00012DF0                 Actuator <1, 0xFF, 0>
00012DF4                 Actuator <1, 0xFF, 0>
00012DF8                 Actuator <1, 0xFF, 0x10>
00012DFC                 Actuator <1, 0xFF, 8>
00012E00                 Actuator <1, 0xFF, 4>
00012E04                 Actuator <1, 0xFF, 2>
00012E08                 Actuator <1, 0xFF, 1>
00012E0C                 Actuator <0, 0xFF, 0>
00012E10                 Actuator <0, 0xFF, 0>
00012E14                 Actuator <0, 0xFF, 0x2000>
00012E18                 Actuator <0, 0xFF, 0x1000>
00012E1C                 Actuator <0, 0xFF, 0x800>
00012E20                 Actuator <0, 0xFF, 0x400>
00012E24                 Actuator <0, 0xFF, 0x200>
00012E28                 Actuator <0, 0xFF, 0x100>
00012E2C                 Actuator <0, 0xFF, 0x82>
00012E30                 Actuator <0, 0xFF, 0x40>
00012E34                 Actuator <0, 0xFF, 0x20>
00012E38                 Actuator <0, 0xFF, 0x10>
00012E3C                 Actuator <0, 0xFF, 8>
00012E40                 Actuator <0, 0xFF, 4>
00012E44                 Actuator <0, 0xFF, 2>
Old Aug 11, 2009, 03:17 PM
acamus's Avatar
Originally Posted by Deepnine
good stuff. I checked my disassembly.
CD, CE ac fan (hi/lo)
CF, D0 main fan (hi/lo)
D3 boost solenoid
D5 EGR solenoid
D7 Purge solenoid
CB maybe something with ALS
I don't have access to my car at the moment, it needs to be checked.
DA-DD -> disable injector 1-4 as found by Bez
Below are some that i have tested on my bench today:
CD, CE fan (hi/lo)
D5 - EGR
D7 - Purge
D8 - Fuel pump
So we have found two new. Hamish do you want to join - only two of your actuators are now missing....
Old Aug 11, 2009, 05:04 PM
Ceddy's Avatar
Acamus the code you posted above for the H8, is it like a jump table?
The MUT command are in sequential order and the data is addresses to the MUT Command routines?
Sorry, I don't understand whats going on there. Could you explain.
All the H8s I have looked at have a Case statement:
If 0xCA Then
Else If 0xCB Then
Else If 0xCB Then
etc...
(Sorry if my Pseudo Code is bad)
I'll try to test C3 for 5 Deg BTDC, tomorrow when I have some daylight.
Thanks much for finding the other Commands.
Old Aug 12, 2009, 12:31 AM
acamus's Avatar
It is a table of bits corresponding to actuator commands.
e.g. when D8 is received the last actuator structure from the table is taken, i.e.
now the index_of_actuator_word is 0 so bitmask 0x2 is applied on MUT_Command_Actuator_0 i.e.
or MUT_Command_Actuator_0, 0x02 (or r1, r10)
if you search occurrences of where MUT_Command_Actuator_0 & 0x02 is checked you will find actual places where the command is executed.
I hope I have expressed it understandably.
Old Aug 12, 2009, 01:59 AM
Ceddy's Avatar
Thanks,
I think the previous Case routine I mentioned earlier is for MUT over OBD2.
My H8 has 3 protocols: MUT, OBD2, and MUT over OBD2.
Code:
seg000:3BC8 01 FF 00 00     ActuatorBitMsk:     .long 0x1FF0000
seg000:3BCC 01 FF 00 00                         .long 0x1FF0000
seg000:3BD0 01 FF 00 00                         .long 0x1FF0000
seg000:3BD4 01 FF 00 00                         .long 0x1FF0000
seg000:3BD8 01 FF 00 00                         .long 0x1FF0000
seg000:3BDC 01 FF 00 10                         .long 0x1FF0010
seg000:3BE0 01 FF 00 00                         .long 0x1FF0000
seg000:3BE4 01 FF 00 04                         .long 0x1FF0004
seg000:3BE8 01 FF 00 02                         .long 0x1FF0002
seg000:3BEC 01 FF 00 01                         .long 0x1FF0001
seg000:3BF0 00 FF 00 00                         .long 0xFF0000
seg000:3BF4 00 FF 00 00                         .long 0xFF0000
seg000:3BF8 00 FF 20 00                         .long 0xFF2000
seg000:3BFC 00 FF 10 00                         .long 0xFF1000
seg000:3C00 00 FF 08 00                         .long 0xFF0800
seg000:3C04 00 FF 04 00                         .long 0xFF0400
seg000:3C08 00 FF 02 00                         .long 0xFF0200
seg000:3C0C 00 FF 01 00                         .long 0xFF0100
seg000:3C10 00 FF 00 82                         .long 0xFF0082
seg000:3C14 00 FF 00 40                         .long 0xFF0040
seg000:3C18 00 FF 00 20                         .long 0xFF0020
seg000:3C1C 00 FF 00 10                         .long 0xFF0010
seg000:3C20 00 FF 00 08                         .long 0xFF0008
seg000:3C24 00 FF 00 04                         .long 0xFF0004
seg000:3C28 00 FF 00 02                         .long 0xFF0002
This is from my 20550011 98 GST Eclipse ROM.
The first entry is Command C0 and the last is D8.
The first byte determines which Actuator to write to, my case 0=F620 and 1=F622.
And the last two bytes are the bit mask for that command.
Correct??
Thanks very much for finding this, I would never have found it on my own.
Old Aug 12, 2009, 02:22 AM
acamus's Avatar
Correct
Old Oct 5, 2009, 05:13 PM
logic's Avatar
I didn't see an update to this posted anywhere, but here's what I worked out today:
C3 - SAS (for BISS adjustment)
D9 - Fix timing to 5 degrees BTDC
I've started a list collecting what we have here in this thread over on the wiki, in case anyone else has additional commands to share, or wants to expand/correct the existing definitions.
Old Oct 5, 2009, 07:23 PM
Ceddy's Avatar
In my H8 DSM ecu and cars without ETACS:
FE: Returns High Byte of Logger ID [EB]40
FF: Returns Low Byte of Logger ID EB[40]
Newer Cars with ETACS:
Return the Immobilizer and Init Codes, if ETACS is validated.
Otherwise it returns the Logger ID.
(I think. I thought a saw some old screen shots of EvoScan that had the Evo ecu displaying the Logger ID, and thats what I got from Acamus's post.)
The Calibration ID seems to return ID flipped around, maybe someone can confirm this.
EC: Cal ID Byte 3
ED: Cal ID Byte 2
EE: Cal ID Byte 1
EF: Cal ID Byte 0
F3: clears the Actuator BitFlags, think this is sent after Actuator commands to put things back to normal. Should be confirmed by someone in case I'm mistaken.
CA & CB: Test two words, but Returns FF no matter what.
C4 & C6: Does a Logical OR to OBD_Faults, but only under some conditions. Not sure what they are doing yet.
F7: Returns FF.
F8: Might reset the 5-baud Init. Like "End Transmission" it resets the comms and you have to resend the Init. But I could be way off on this one.
Any of the commands that return FF, might do something in other ecus.
Edit:
Logic, did you confirm D9 works for Timing Adjustment? I tried to trace it out quick, but it got passed between four BitFlag Words before I got lost.
Old Oct 5, 2009, 07:49 PM
logic's Avatar
Actually, your summary jives pretty well with what I'd observed on the SH ECUs.
CA and CB are basically no-ops.
EC through EF address the cal ID.
I didn't dig too far through FE and FF although I ended up getting back EB40 when testing manually with EvoScan.
F3 is a nice find, if it works; my way of "fixing" things has generally been to disconnect; things appear to go back to normal after MUT comms complete.
Old Oct 5, 2009, 09:34 PM
acamus's Avatar
Very nice work logic. Keep us posted with new findings.
We do have some more solenoids to have commands for
e.g. waste gate
Maybe you can correct SAS description on your wiki.
Old Oct 6, 2009, 06:06 AM
logic's Avatar
Good catch; it's corrected, and I added a page to the wiki quoting the FSM for SAS adjustment.
Old Oct 6, 2009, 02:22 PM
Fast_Freddie's Avatar
Sweet perhaps you guys can stumble across a mut command that will reset the VIII ecus for fuel trims
Old Oct 6, 2009, 03:05 PM
logic's Avatar
The live-mapping stuff can do that, actually, if you really want it. I've been meaning to suggest to Eric or ziad that a button for "zap fuel trims" be added.
(What I'd really like to see added would be a new MUT command that does nothing but zero RAM and force a reboot.)
Quick Reply: MUT Commands Known?
