reflashing evo 7 ecu on evo 5
Old Jul 29, 2009, 03:49 PM
maximusnz's Avatar
Hey everyone I'm new on this forum,
I've just received my 1.3 cable and I'm wanting to reflash my ecu. I've noticed that my evo 5 doesn't have the white connector for the reflash plug that is attached with the cable.
Is it possible to connect that wire to pin 79 so I can reflash my evo 7 ecu.
Thanks
Max
Old Jul 29, 2009, 03:57 PM
evonut270's Avatar
the 5 does have a flash connector. but yes if your struggling you can connect the wire to pin 79
Old Jul 29, 2009, 04:14 PM
maximusnz's Avatar
I checked and there isnt a flash connector
Old Jul 29, 2009, 04:22 PM
evonut270's Avatar
it will be hiding in the loom near the obd port.iv had problems finding them before.
Old Jul 29, 2009, 04:28 PM
maximusnz's Avatar
sweet as, ill have another look, thanks for the reply
Old Jul 29, 2009, 04:32 PM
Mellon Racing's Avatar
which mas are you going to use with your 5?
Old Jul 29, 2009, 04:44 PM
maximusnz's Avatar
I'm going to reflash my evo 7 ecu with a evo 7 ralliart rom
Old Jul 29, 2009, 04:45 PM
so you're keeping the stock evo 5 mas and going to flash the evo 7 ralliart ROM on the car???
Old Jul 29, 2009, 04:51 PM
evonut270's Avatar
there is very little between the 5 maf and 7 maf in terms of size and scaling.
Old Jul 29, 2009, 04:53 PM
maximusnz's Avatar
if I have to change the maf then I would no problems
Old Jul 29, 2009, 04:56 PM
if they aren't exactly the same that wouldn't be acceptable to me and I sure wouldn't throw a RalliArt tune from a 7 on it to make matters worse and call it good
Old Jul 29, 2009, 04:57 PM
evonut270's Avatar
you dont have to change the maf.just change the scalings + size
Old Jul 29, 2009, 04:59 PM
maximusnz's Avatar
cheers everyone
evonut270's Avatar
me either which is why the scaings should be changed.but the stock scalings will be enough to get it fired up.theres been plenty done with this conversion with no probs
Old Jul 29, 2009, 05:01 PM
NOW you're following my questioning of the OP's decision
Quick Reply: reflashing evo 7 ecu on evo 5
