ROM 88840017 - JDM MAP and TE 2J1 WB
#76
<scaling name="FuelCutLoadX2" units="%" toexpr="x*5/2" frexpr="x*2/5" format="%.0f" min="0" max="638" inc="1" storagetype="uint8" endian="big"/>
<table name="EXTU.W->SHLL (6DDD -> 4D00) for Fuel Cut Load X2" category="Turbo Mods" address="14854" type="1D" level="1" scaling="Hex16"/>
<table name="Fuel Cut Load X2" category="Turbo Mods" type="2D" level="1" address="3050" scaling="FuelCutLoadX2">
<table name="RPM" type="Y Axis" elements="9" address="77ae" scaling="RPM"/>
</table>
</table>
Hello Donner,
I test it and seems like didnt working :S I made qutie a lot log and change the multiplier to 4D00 but boost cut applied at over ~300 load . Here are the screenshoots :
high boost :
More boost :
Lower boost no problem :
Lower boost no problem 2 :
Any idea what to do to run more boost and no cut and load problem ?
#77
Also I tried your rom, the 88583714_DMA_SD . Seems like it is working great . I didnt tune it too much just tried how better the car goes with it, and tried the boost cut load X2 table too but also not worked The Evo 9 was runing so so smooth.
Do you have the Speed density 2.0 3D SD rom for the EU Evo too ? Tomorrow maybe I can try it . Thanks a lot !
#78
There is also two other limits (but these are not limiting in speed density mod and should be left as is from factory):
<table name="Set from 2BA1 to 0009 to remove load limit 380" category="Fuel Mods" address="28A5E" type="1D" level="1" scaling="Hex16"/>
<table name="Set from 2BA1 to 0009 to remove fuel IPW limit" category="Fuel Mods" address="28B84" type="1D" level="1" scaling="Hex16"/>
#79
Gergo, are you really cutting fuel when you hit that "limit"? For me it looks more like you are just overflowing 1-byte load. Set your multiplier of 1-byte load to bigger value than 1.2 in your rom and in evoscan (I presume you have 1.2 as 1-byte max value is 255x1.2=306). 1-byte is only for logging and should not cause real fuel cut.
#80
You are true ! sorry ! hit the load limit yes... I have to change the load factor and have a try . At afternoon will do it and let you know here at night !
V7 roms also useing 2byte different compensated load for timing and fuel tables ?
#82
turn of all of the limit what I get from Donner, set the load factor higher and no more problem !
The 3D SD DMA rom for Eu Evo 9 is working flawless ! Drove the car 10 minutes with the rom because the time was so late, no jitter issue no driving problem just simple working great ! Tune the maps 3 times and made some wot pull succesfull ! The DMA didnt test yet !
Donner it is great !
#83
#84
sorry to wake up this old threat but im doing same SD on EDM evo 9.
i checked list of items to buy but i can't find no where one Evo IX ECU pin.
somebody can help me?
thank you
thank you
#85
xPRimNT
157
Dec 26, 2018 08:09 AM
Bewstzalot
Jul 7, 2017 01:35 PM
kalendrinn
Dec 14, 2015 10:40 PM
