Best 2 Step Settings
I know this happened to me when I first started dragging. I would stay on it too long and I would launch and it would pull timing like a **** and bog all to hell. So now what I do and see others do is just rev it up to like 5k if the 2step is @ 6k. Then when the lights start dropping I go WOT and stay on the 2 step very briefly.
I have seen people putting -10 in the timing areas where the 2step is for the best buildup of boost.
Registered User
i dont know what difference this will cause.
EvoM Community Team
I personally think the increased knock and possible damage from going all the way to -10 are not worth the extra couple of lbs that you get, especially since you will build most of that instantly as load starts to increase. I recommend something closer to 5* or wherever you don't knock when you start to let out the clutch.
Where is the "2 step area" of the map ? ?
Yes, I know I could just log it for myself....but we have all of this experience on these boards and everyone is so secretive.
