Map Tracing on EvoScan v2.6 ?
Alright well the evoscan is linked with ecuflash with the intended effect to allow you to now map trace.
I've been playing with it and so far I've gotten it to do a Map Tracing Replay from the Sample log file but that's about it. I've haven't been able to get it to work on one of my own logs (recorded within v2.6) or in real time at all. Has anyone played with this or figured it out yet?
For the guys who haven't had a chance to take a look at it and plan on doing so here's the crash course to get to where i am now...
Open up Evoscan and at the top click the "Graph's & Map Tracer" menu. Select either "Real Time Logging" and then "Map Tracer" at the bottom [OR] "Analyze Log File : Map Tracer" for a more direct route. Now choose the log file "Sample1" and when the window loads go to the bottom map window and RIGHT CLICK to select a ROM FILE. You can also change from Fuel Map to Ignition Map by right clicking the bottom window. Now select the field from the left that you would like to have map traced and the results will be displayed in the top window.
Its not real time but it'll get the job done so long as it'll work on log files other then the samples.
Any other insight on the mater would be very appreciated.
Search Button Failed Me: Did four searches and found nothing, then Google pops this up an hour later....
https://www.evolutionm.net/forums/ec...ap-tracer.html
But even so... my issue is that the log is not reading. The rom loads and displays fine. The sample works just nothing that i've recorded my self. And I've tested it on a log with everything selected. I don't get any messages or error codes just nothing displays up above.
EvoM Community Team
evo4mad
May 5, 2015 06:22 PM
