I need a 2003 stock map,,,
Yes and no. You have to use the same family. The "9417" in the beginning is the family. Then the last number 0007, 0008, 0015, is the version of that family. So the "94170015" is the most current version of the "9417" family.
As long as you use the same family youll be ok. (even though you can use a ROM from a different family, but you have to make some tweeks to get it to work)
Also, let me know if you fix that problem we were looking into.
Maybe thats why im havin problems setting the 2step,,,, So I should try a udated rom,,,,,
Also, if you just need CEl knock lite, NLTS or valet. You may even want use one of the original tepha patches (before it was called the tephra mod) as they are way more simple compared to the V6 (if your using that).
Also, i think that all the stock ROMs are at activmatrix or osecuroms
Ok thanks,,,,,, good info..
Yeah.
fyreant
Sep 28, 2010 11:00 AM
