Load based boost help please
Old Oct 5, 2009 | 12:47 PM
  #31
house_of_senate's Avatar
Bump for a little input
Old Oct 5, 2009 | 02:02 PM
  #32
John F's Avatar
You're running too much duty cycle and desired engine load between 3000 and 4500rpm. Make your desired engine load 120 in these areas and adjust the duty cycle accordingly by logging load error. This will eliminate your boost spike. From here you can easily fine tune to the boost you are aiming for.
What boost curve are you trying to make?
Old Oct 5, 2009 | 02:22 PM
  #33
My boost spike is pretty much gone now, it just jumps up and down the entire time in 4th gear. Just trying to hit 30 psi and hold it as long as possible.
Old Oct 5, 2009 | 02:41 PM
  #34
John F's Avatar
Here's a graph of your load v RPM. Your only issue is 3250 to 4250 rpm. Seriously, just zero out your error correction table and drop the desired engine load and duty cycle. This will smooth things out nicely. Add the numbers back into error correction once the duty cycle is dialled in.
Old Oct 5, 2009 | 02:52 PM
  #35
My duty cycle was perfect when the tbec was zeroed out is the thing that I dont get.
Old Oct 5, 2009 | 03:04 PM
  #36
GST Motorsports's Avatar
zero out 2.5 and try even smaller downward correction. and/or buffer the BDEL a bit more
Old Oct 5, 2009 | 04:33 PM
  #37
How much would you buffer the bdel?
Kaveeth
Jan 26, 2015 05:35 PM
Seijuro
Mar 20, 2010 11:53 AM
CornFedEvo
Dec 4, 2009 09:43 PM
THUB
Oct 16, 2008 09:38 PM
lemmonhead
Apr 19, 2008 09:05 PM
Quick Reply: Load based boost help please
