Tephra v7 9653 thottle hang
#166
again, i believe this happened only after switching to V7 from V5.
#167
Zeroing out the two tables I mentioned will remove 90% of throttle hang.
If you have some left over, you can fix the rest by playing with your base idle screw and/or the idle tables.
If your base idle screw is too far open, it will throttle hang a bit since there is extra air getting in. By lowering some of the idle tables, it will open the idle stepper motor less and achieve the same effect as closing the base idle screw.
