Poor Cold Idle (Yes I searched)
Old Nov 4, 2009, 07:58 PM
  #196
Appauldd's Avatar
add this scaling....
<scaling name="Percent255" units="%" toexpr="100*x/255" frexpr="255*x/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big" />
Old Nov 4, 2009, 08:15 PM
  #197
Evoryder's Avatar
Thanks Paul, gonna load it in the morning. The "hole of 5's" I don't have or see...
Old Nov 4, 2009, 09:14 PM
  #198
Appauldd's Avatar
The "unknown ignition table" (hole of -5s) has not been located in 94170015.
Old Nov 4, 2009, 09:17 PM
  #199
Evoryder's Avatar
ok cool, you can go to bed now lol
Old Nov 4, 2009, 09:26 PM
  #200
Appauldd's Avatar
Sleep...HA
Sleep is a crutch.....I'll sleep when I am dead!
Old Nov 5, 2009, 12:15 AM
  #201
Fast_Freddie's Avatar
Yeah for the 05's the ISCVs are a bit different, I left the V7 values in there. Once the car figures out what is going on everything is much better. I finally haven't changed anything on the car in over a week and the car is running really, really good. I am putting in new ID 1000's next week in preparation for a FP Red. That is going to introduce a whole new variable to the mix. I am praying that I don't have hot start issues.
Old Nov 5, 2009, 04:16 AM
  #202
Evoryder's Avatar
Zeroing the values did nothing, same rpm spike
Old Nov 5, 2009, 06:17 AM
  #203
I take it you have adjusted your biss? Which ROM are you using?
Old Nov 5, 2009, 07:31 AM
  #204
Appauldd's Avatar
Freddie....the hole of -5s table isn't in the 9417 rom. He is using 94170015.
Old Nov 5, 2009, 07:49 AM
  #205
Evoryder's Avatar
I had to adjust the biss after installing a 65mm TB. It idles fine once warmed up it's just the initial spike which is annoying
Old Nov 5, 2009, 10:46 AM
  #206
Appauldd's Avatar
Try some ISCV adjustment.
Old Nov 5, 2009, 11:55 AM
  #207
Evoryder's Avatar
Adjust what values?
Old Nov 5, 2009, 12:23 PM
  #208
Appauldd's Avatar
Adjust what values?
The desired ISCV initial step position tables. Since my car was originally on 96530008 I input these ISCV values into my v7 rom. The car idles much smoother with no initial jump in RPM. I am on Revolver cams and have idle set at 1125 rpm. Any lower and the car is just too lopy for my taste.
AC off Neutral (I did raise the last entry...the 10...up from stock of 7)
145
126
116
116
93
68
17
10
AC off Drive
180
164
153
144
130
102
48
36
AC ON-Neutral
255
242
228
212
186
150
88
80
Old Nov 5, 2009, 12:24 PM
  #209
Appauldd's Avatar
I logged cold start today and I confirmed that the car does, in fact, idle at -5* timing when cold. Thus, this table of -5s is certainly being called.
Old Nov 5, 2009, 01:20 PM
  #210
Evoryder's Avatar
I'll try, thnks Paul
Quick Reply: Poor Cold Idle (Yes I searched)
