TephraMod V7
Old Apr 15, 2010 | 10:47 AM
  #1681
And's Avatar
And
did you notice an other problems with them? was that tried on 3 different cars or the same car and 3 different ecus?
Old Apr 15, 2010 | 10:50 AM
  #1682
cossie1's Avatar
I personally tried it on my own car, same ecu 3 different roms.
But Jamie_VI also tried the same roms on his car, with a 7 and an 8 260 ecu and had the exact same issue's.
Old Apr 15, 2010 | 11:36 AM
  #1683
project_skyline's Avatar
Does anyone know the MUT address and Evoscan code for logging IAT+baro compensated 2byte load(9653x06)
Old Apr 15, 2010 | 04:30 PM
  #1684
VGergo's Avatar
With the "Option 2 94170715 (v7 + Mods Omni 4 Bar MAP)" the car run by MAF sensor and will have Ecu based direct boost controll ? And I can use the GM boost control solenoid too ?
Old Apr 15, 2010 | 06:16 PM
  #1685
Appauldd's Avatar
^ YES. You can do all of that. Just make sure you set up your MAP sensor correctly.
Old Apr 15, 2010 | 06:18 PM
  #1686
RoadSpike's Avatar
Speaking of sensors I got the 7 bar mappings worked out for any drag car insane enough to do it.
https://www.evolutionm.net/forums/ec...-scalings.html
Old Apr 16, 2010 | 12:47 AM
  #1687
VGergo's Avatar
Okay, thank you !
off question : does someone know the evo 8 engine harness where are in connect with other harness of the car ?
Old Apr 16, 2010 | 04:53 AM
  #1688
bigric09's Avatar
Last i checked it comes out of the passenger side floor board thru the firewall directly from the ecu into the engine bay. Routes around to the fuse box.
Old Apr 17, 2010 | 09:07 PM
  #1689
PlanoEvo's Avatar
awesome work
Old Apr 18, 2010 | 01:19 AM
  #1690
evoscan's Avatar
Silver Sponsor
Hey Dudes, whats up... i'm back to help you guys out. A lot of new stuff coming out this year for EvoScan and EvoScan Standalone Unit. -subscribed.
Old Apr 18, 2010 | 09:45 AM
  #1691
Jim in Tucson's Avatar
Details! Details!
Old Apr 18, 2010 | 11:38 AM
  #1692
mfr122887's Avatar
I think the Mileage (Gasoline) formula in the second post needs to be updated.
It is listed as Eval="5.9*[Speed]*[AFRMAP]/[lbamin]"
I am getting values in the 1000's.
=5.9 * 60 * 14.7 / 5
=1040
I don't think I am doing anything wrong because the math just doesn't work.
I also noticed that in 94170715, it defaults to the alt map. I loaded up the ROM with the alt maps option set to 0 to disable them and then logged 8425 and received 3. In the past this meant that the ecu is using alt maps, has this changed in this ROM?
Old Apr 18, 2010 | 07:08 PM
  #1693
mchuang's Avatar
Does anyone how easy it would be to convert back to the old style psi boost settings without being gear dependent as i do not see myself going 140 mph plus to tune 5th gear on the street.
Old Apr 18, 2010 | 07:12 PM
  #1694
RoadSpike's Avatar
If that's your goal for ease of setup just set every gear the same saves you both time and effort undoing tephra's work.
Old Apr 18, 2010 | 07:13 PM
  #1695
tephra's Avatar
yeah.. just copy your 4th to your 5th column...
Quick Reply: TephraMod V7
