TephraMod V7
#1696
[QUOTE=yeah.. just copy your 4th to your 5th column...[/QUOTE]
Tephra are you referring to the main wastegate map?
#1697
#1699
Gotcha. I actually did have them the same values. I was having some boost issues. Could be possible because i switched from stock enkies to 18x9 245/40 wheel/tire setup.
#1700
I'm not entirely sure how manipulating the table would go. If you set every value to the same gear I'd have to imagine it wouldn't matter.
#1701
that would work... but really your defeating the purpose of the gear based boost then...
you should be able to tune 1/2/3/4 and then copy 4 to 5/6
4/5/6 will be very similar and also TBEC has enough time with those gears..
1/2/3 is the biggest advantage for gear'd boost
#1702
#1704
I think the Mileage (Gasoline) formula in the second post needs to be updated.
It is listed as Eval="5.9*[Speed]*[AFRMAP]/[lbamin]"
I am getting values in the 1000's.
=5.9 * 60 * 14.7 / 5
=1040
I don't think I am doing anything wrong because the math just doesn't work.
I also noticed that in 94170715, it defaults to the alt map. I loaded up the ROM with the alt maps option set to 0 to disable them and then logged 8425 and received 3. In the past this meant that the ecu is using alt maps, has this changed in this ROM?
=1040
Multiplying the airflow by 60 converts lbs/min to lbs/hr. Then all the units will cancel leaving you with miles per gallon.
Anyone else log 8425 in 94170715 and notice that it defaults to 3 signifying alt maps?
#1705
Hello
The map switching with V7+maf to get 2 different fuel ignition and boost table only availabe if you run with ecu based direct boost control and plug in for it a MAP sensor ?
The ALS table coud copy in the rom to control the SAS with the solenoid ? V7 can retard ignition -10 or -20 ? Is there any way to add more fuel when decelerate and the throttle is closed ?
Can I run with different MAF sensor If i know calibration ? I have the MD336481 .
#1706
Anyone else still having crazy cold start idle.... Mine goes all over the place for a little bit. It will swing from 1000 to 2000 then 1500 and back up and down. I have have tried to change a few things but nothing seems to do the trick. I am going to try and reflash it with a newer version of the 94170715.
#1708
I did some searching through the thread and I'm still a little confused about the BWGD & BDEL replacement maps. Do I just copy and paste my previous ROMS values in and make each gear the same? Sorry for the newb question I'm still trying wrap my mind around alot it. Thanks
#1710
Ok That is what I was thinking. Another question that came to mind is that I'm using a MBC.. How would this interact with gear based boost control. again newb question. Thanks
