TephraMod V7
#1726
#1731
given all the FREE time you've given to these projects, i don't think anyone can really complain.
cam install is this weekend. then fuel pump and injectors. i believe Jay is going to the big map/v.7. we'll see how it goes.
{bigthumb}
#1732
I have been searching and not wanting to read through 1700+ responses, but has the lean spool been routines been removed by V7 on the 97140715 ROM?
Or any ROM for that matter... lean spool, yes? no?
#1733
Yes, i would like to know where i can get lean spool as well. Also, im putting this evo ecu in my eclipse and want to know how i can wire up for Sd. I already have the MAP sensor plugged into the old MDP sensor on the eclipse and was planning on using the maf connector for the temp sensor. Would i just have to trace the wire to the one i use to switch the pin for the fuel temp to make it work?
TIA
TIA
#1735
#1736
Just to clarify:
When you mentioned leaving lean spool in default state, does it "automatically" set lean spool to default factory settings (i.e. on at 2500rpm) or default (from last loaded map settings)?
I noted that the Idle Stability Timing Control is not in as well. Any reasons for not having that in? Or is there any other ways to stabilise weird idling (especially for those with big cams)? If I need to add, can I use back the same address that was previously on my xml file?
