TephraMod V7
Old Jun 3, 2010 | 12:01 AM
  #1816
VGergo's Avatar
What kind of fixing making on the V7 94170715-TephraMod-phenem ?
Old Jun 3, 2010 | 10:38 AM
  #1817
95630706's Avatar
LOL. I think the non-speed density version is fixed. It's on the Wiki here:
http://evoecu.logic.net/wiki/File:94170715-v7.zip
I'm still looking for the SD version... I think it's still getting fixed.
Old Jun 3, 2010 | 04:51 PM
  #1818
VGergo's Avatar
interesting.. : "PSI based boost control error fix"
What does it mean, because I have problem with the boost controling seems like my psi based doesnt work. Only load one. But I have the Phenem one which are for Omni power 4bar and in the global boost setting everything was set for psi based boost.
the 96530706 is better ?
Old Jun 6, 2010 | 06:13 PM
  #1819
Creamo3's Avatar
Any idea on what's being "fixed"; I want to compare 9417 to 9563 for SD.
Old Jun 8, 2010 | 03:25 AM
  #1820
markyang83's Avatar
any update for 88570008? thx
Old Jun 8, 2010 | 01:26 PM
  #1821
VGergo's Avatar
Is it a good ide to run with Evo 9 maf on the Evo 8 with tephra Evo 8 rom ? Or the scaling is so much different and best to buy an Evo 8 maf ?
Old Jun 8, 2010 | 02:13 PM
  #1822
GST Motorsports's Avatar
The maf is different but you should be able to just copy it over
Old Jun 8, 2010 | 02:53 PM
  #1823
VGergo's Avatar
Hello, thank you, just copy over the maf scaling and maf compensation ( maf smoother ) table ? What does maf adder mean ? I'm using the 94171715 but in the Evo 9 tephra rom maf tables has different scale same as for the Evo 8 tephra in the 96530006 .
Just an other question : If i have the right maf scaling and maf compensation table + maf size than I coud use any other Mitsubishi MAF just copy over the right tables ?
Old Jun 8, 2010 | 09:36 PM
  #1824
RoadSpike's Avatar
Phenem noticed cranking primer enrichment wasn't properly defined for your xml pack it was pointed to 3810 when its supposed to be 5b14.
Few other things too so i've made a sample xml for your consumption.
Applies to 94170015 based roms only.
File Type: zip
Old Jun 8, 2010 | 09:39 PM
  #1825
03lances's Avatar
Wait I thought the evo 8 and 9 maf were the same? I have a maf out of a 9 but have been running 8 maf settings cause I thought everything was the same am I mistaken?
Old Jun 8, 2010 | 09:44 PM
  #1826
RoadSpike's Avatar
Scaling is the same
Size is the same
Maf smoothing is different
Old Jun 8, 2010 | 09:51 PM
  #1827
03lances's Avatar
Originally Posted by RoadSpike
Scaling is the same
Size is the same
Oh I missed that I will have to change that in my rom then
Old Jun 9, 2010 | 12:38 PM
  #1828
tscompusa2's Avatar
how much longer until ecu boost control is fixed on 94170015? wiki says its fixed but phenoms rom says its not in the opening thread posts.....
Old Jun 9, 2010 | 12:47 PM
  #1829
RoadSpike's Avatar
works for me just have to implement the gear fix
Old Jun 9, 2010 | 12:49 PM
  #1830
tscompusa2's Avatar
ah ok nice. so the one in the wiki is the fix? i will talk with appauldd tonight if he comes on google talk.
Quick Reply: TephraMod V7
