TephraMod V7
#2041
Yeah I think its closed loop, Given the inaccuracies of oil pressure I would say it would have to be...
I have no details on the algoritm - and thus no tables to give you to play with
With the X we see the InMIVEC reacting pretty quickly, the ExMIVEC lags behind..
I think thats because the ExMIVEC is done by closing ATDC degrees, rather than opening degrees BTDC (like InMIVEC)..
#2042
#2045
below is what i posted in another v7 thread. i'd like to get this working, any thoughts
started setting up v7 and didnt have much luck. transfered everything i could find in my old map over to the new one. my current rom is 88590015 running speed density. i downloaded the modded rom from the v7 thread 88591715 and when i crank up the car the idle is more lean than the wideband can display. i dont have my wideband setup for looging yet. also, idle related, it didnt want to stay on at first but once i let it warm up it stayed on but stayed pretty lean, around 16-17 afr's.
thoughts?
thoughts?
#2053
#2055
