TephraMod V7
#2057
Oh, and I have donated for 9055, so waiting on that.................
#2059
#2060
#2061
#2062
Hello
I have to 2 Evo 9 maybe European Ecu.
The first one ID is 88840013. Can I upload on it the Tephra V7 88590715 ?
The second one can not open have no XML.. Maybe someone coud ? I would need the immobilizier code from it. and the same question can upgrade it with V7 88590715 ?
the rom what i can not open
Thanks a lot !
Thanks a lot !
#2063
Has the jdm map settings changed? The setting for roms used on usdm evo9 does not match what was originally posted in other threads? I am using 88590715 but when I try to load 88591715 the car runs rich and back fires heavily when the throttle is pressed. AFR reads 10-11. Anyone have any ideas.
#2064
is it possible to change the order in which the tables appear in ecuflash for this rom? i do not use the alt maps and dont want to scroll all the way halfway down or minimize the tables just to get to the main maps
#2065
I have EDM EvoIX that initially ran 88840016. Few kmiles ago I uploaded it with Tephra v7 ROM 88580714 and it works like a champ. From wmat I know it is correct Tephra ROM for EDM Evos (88590715 is not the correct one).
As for the ROM that you cannot open, it appears to have ID 88580015, for which I have no definition file. Maybe other more knowledgeable users can help you with definition file or suggest suitable definition file from other ROM.
Hello
Thanks a lot !
Thanks a lot !
#2067
Can we run with psi based boost control on the 88580714 ?
VD : can you log boost in Evoscan just select JDM map request 38 ?
#2070
This is for you - https://www.evolutionm.net/forums/ec...te-2j1-wb.html
