TephraMod V7
Old Nov 17, 2010 | 03:59 PM
  #2101
tephra's Avatar
do the SAS-disable (or whatever its called in EvoScan) - which will disable idle control.
then reset the idle screw
Old Nov 18, 2010 | 12:35 AM
  #2102
raulhp's Avatar
Thanks for your reply tephra...I want give you many thanks for your work on the roms, seriously
What is SAS? if you can tell me what is it, i can looking for if it has another name...Perhaps i can do it unplug the wire from the idle engine directly...
then you say about reset the idle screw...must i fix the screw to my target RPM...?
It is the same system like i need to do when i tune a hydra ecu...if you need any question about Hydra ecus or Kpros etc, or something like that, please feel free about this
Old Nov 18, 2010 | 05:35 AM
  #2103
Raptord's Avatar
SAS = speed adjusting screw
Activate the SAS actuator with Evoscan, then adjust the BISS on top of the throttle body to get your idle to where you want it.
Old Nov 18, 2010 | 02:48 PM
  #2104
tephra's Avatar
obviously warm the car up first
Old Nov 18, 2010 | 03:01 PM
  #2105
ziad's Avatar
96260009 v7?????
Old Nov 18, 2010 | 03:43 PM
  #2106
tephra's Avatar
hey all,
I will be doing a final bit of coding for CT9A, I want to wrap up a few outstanding ROM's, namely 90550001, 96260009 and 88570008.
If you have a desperate desire to get another ROM added, let me know NOW and I will see what I can do.
I will be making the above ROM's available to those that have sent through donations for them so far. So if you want a copy... you know what todo
Old Nov 18, 2010 | 04:39 PM
  #2107
philr8's Avatar
Tephra is 96260009 and 90550001 V7 available now? If so donation on its way
Phil
Originally Posted by tephra
hey all,
Old Nov 18, 2010 | 04:40 PM
  #2108
tephra's Avatar
not yet...
Old Nov 18, 2010 | 05:05 PM
  #2109
ecktt's Avatar
Yeeha!
90550001
Man I just might donate again!
Old Nov 18, 2010 | 09:19 PM
  #2110
Benja's Avatar
Donated for 9055001 mate.
Cheers.
Old Nov 19, 2010 | 05:53 AM
  #2111
Icem@n's Avatar
Originally Posted by ecktt
Yeeha!
90550001
X2 ........ i might do the same also.
Old Nov 19, 2010 | 08:04 AM
  #2112
ramievo7's Avatar
90550001 , how can i donate guys ? through paypal?
Old Nov 19, 2010 | 08:16 AM
  #2113
ecktt's Avatar
Look at tephra's sig
Old Nov 19, 2010 | 12:52 PM
  #2114
Benja's Avatar
Through PayPal to the address in his sig.
Old Dec 8, 2010 | 09:45 PM
  #2115
ug_orf's Avatar
hey all,
Tephra is 90550001 V7 available?
Quick Reply: TephraMod V7
