TephraMod V7
#2131
"8884001X - You can use 88580714 with no problems. Just ensure you copy your immobiliser AND 0xFFA bits (yes 0xFFA) otherwise the immobiliser wont work "
What to do with FFA bits to work the immo in the EU cars ? I cant see my original rom FFA settings.. which bits are important ?
#2132
if i dont remenber bad, the US and Euro cars has not manifold pressure sensor, only the japanese model
if you disconect the fuel pressure hose, your fuel pressure is static, and the injector pulse is tuned versus the fuel pressure...that it means that in idle your car would be very rich and your fuel trims would work a lot to get the 14.7 A/F
Then in boost, your can can be lean, because the fuel pressure regulator, gets more pressure under boost to win the pressure inside the engine and inject fuel inside. If you disconect it under boost, the injectors will have less fuel pressure, at the same pulse, result less fuel.
You need to conect it again an retune your car
#2135
Donation sent for 90550001 v7
hey all,
I will be doing a final bit of coding for CT9A, I want to wrap up a few outstanding ROM's, namely 90550001, 96260009 and 88570008.
If you have a desperate desire to get another ROM added, let me know NOW and I will see what I can do.
I will be making the above ROM's available to those that have sent through donations for them so far. So if you want a copy... you know what todo
#2136
I have a 2003 usdm evo8, but it is a 5 speed, and the rom indicates use of 6 speed..
Are there any problems with me using the 96530706 rom?
Are the maps/tables already set up for a stock car, or do i have to copy my stock maps over to this one??
My car is completely stock.
#2137
You are fine all of the evo 8 versions ive seen say 6MT. On another note I want to thank tephra, phenem, and all of the other ecu gurus. I recently swithched from the original v7 9653 rom to the 9417 rom to accomodate my new omni 4 bar. This rom is very smooth and I have no problems with throttle hang as I did with the previous rom. So thank you guys you are doing awesome work.
#2138
#2142
Is it right that in this ROM
http://www.globalshare.net/evo-mod/v...phraMod-V7.zip
high octan map richer than low octan?
#2143
E7 ecu swap to E6 with V7 rom - immo problem
Hi
I uploaded 96530706-phenem V7 to mine E7 ecu installed in E6 car, but I can't start the car.
Probably it's immo problem. With "original" E7 rom 97250001 I'm using FFFF value as Immo code, but in 96530706-phenem V7 there are 3 fields:
- immo
- immo hex
- init code
what to put there to start the car ?
- immo
- immo hex
- init code
