TephraMod V7
Old Jul 17, 2011 | 01:18 PM
  #2401
mwbourquin's Avatar
new to this
need help. helping out a good friend who is pretty confused on the whole code part of changing the xml file. have a 92 gsx running gm maf/maf translator and wideband with evo 7 ecu. is running the evo7base rom but needs same options as tephras 96530706-v7 to get rid of cel and tach malfunction. cant get ecu flash to see the code right. get unknown rom image and no definitions in the pull down tab. pleeeeez help thanks
Old Jul 18, 2011 | 05:42 PM
  #2402
gveranda's Avatar
TephraMod V7
Donation made for 98640014 V7
Old Jul 18, 2011 | 08:11 PM
  #2403
tephra's Avatar
there is no 98640714 - but I will send you 90550701 since thats a direct replacement...
Old Jul 19, 2011 | 12:01 AM
  #2404
gveranda's Avatar
Wink
Thanks Tephra received the files.will try out tonight
Old Jul 24, 2011 | 05:37 AM
  #2405
gveranda's Avatar
knocks on cold start with v7
my E7 is recording 38 knocks on start up.can some please tell me if you come across this issue.no issues with my original 98640714.logs attached for both 98640714 and 90550701 v7
So far I've tried below with no luck
turning off and on warm up ign restart in FAA
turning down desired idle rpm about 6%
can someone pleeease help here on this???
File Type: zip
Old Jul 25, 2011 | 02:15 AM
  #2406
Benja's Avatar
Does it do it free-revving?
Sounds like somethings loose.
Never come across that.
Old Jul 25, 2011 | 04:55 AM
  #2407
gveranda's Avatar
Red face
Thanks for the reply Benja I'll go and check if there's anything loose but again its works with no issues with my original rom. will go through all the tables again anyway
Old Jul 26, 2011 | 01:54 AM
  #2408
kiwiracer's Avatar
96531706
is there any chance i could run antilag on the 96531706 ?
Old Jul 26, 2011 | 03:20 AM
  #2409
dparrish's Avatar
No, as far as I know the ALS code does not exist in the 9653 rom. The config tables do and you can edit them all you like, but they won't do anything at all.
Old Jul 26, 2011 | 05:01 PM
  #2410
kiwiracer's Avatar
hmm any speed density roms for the evo 8s that do? ,, what about if you just modified the timing in the main ignition maps (retard) and also bumped the fuel table in the same area.. as far as air maybe open iac fully at same point??
Old Jul 26, 2011 | 11:56 PM
  #2411
dparrish's Avatar
You can retard the timing and add fuel to do launch control. In fact that's how the launch control on the tephra roms work, and that runs fine on 9653.
I'm running 96260709 on my JDM evo 8, which does have the ALS code but I haven't enabled it. I'm not sure if anyone made a SD version of that ROM though...
Old Jul 27, 2011 | 06:41 PM
  #2412
kiwiracer's Avatar
thanks for your reply
so your saying I could put some agressive retard figures in the launch ignition map and add fuel into the cells its spools up in.. what happens on the rev cut?? i thought laugh basically ur foot is hard down and it rev limits at a certain rpm?
Old Jul 27, 2011 | 09:35 PM
  #2413
dparrish's Avatar
There's a thread here where people have posted examples of their launch maps, take a look at them. In EcuFlash you'll find a Stationary Rev Limit map, which you can set to where you want to launch at. I have mine set to 5000 so I set my ignition retard to around -12 degrees at 5000 and smooth out the transition to the normal map as the revs drop.
There's a few threads here on how to set up launch control, it's pretty simple once you're running a tephra rom.
Old Jul 28, 2011 | 02:28 AM
  #2414
kiwiracer's Avatar
yeah i tried slow stationary loading it up with launch enabled, goes way past stationary limit to its main rpm limit. hmm
Old Jul 28, 2011 | 05:13 AM
  #2415
todd6027's Avatar
if its a makinen did you fit a clutch switch ????
Quick Reply: TephraMod V7
