TephraMod V7
#242
I MIGHT have figured out the scaling for BoostErrorPSI,Psia8 and Psia16 for the different Map Sensors so I will email you the revised XML tonight after work Phenem after I go over my math one again
#245
https://www.evolutionm.net/forums/ec...xml-files.html
I used the same numbering system.
Includes the Tephra V5.10 patch on 94170015 for those converting over too.
#246
#250
Just a package that includes all the XML's in case you are experiencing weird data display issues. That way you can have all the XML's that Tephra, JoT, and all of us use during testing so we know you have it setup correctly.
#253
if all else fails then you can use older ecuflash, HOWEVER you MUST change all the endians.
#254
1) Download the correct file
2) Copy the new XML file into the ecuflash directory (rommetadata\mitsubishi\evo)
3) Open the new ROM in ecuflash
4) copy across any maps/settings from your current ROM
5) flash new ROM
6) enjoy!
Cheers
D.
#255
Ok, that's what we've always done, but when I think of reflashing my ECU (presently 94170015) with a 96530006 ROM, a red flag pops up in my mind. Am I just being paranoid? LOL If you're telling me that works, I'm fine.
