TephraMod V7
#2611
okay let me try this real quick and see what happens i think i understand it now
#2613
yea so when i open the tephra i downloaded it shows 2 files the one that looks like the folder allready in it i drag into and then u suppost to exit it all right and when i open it. it should have the 88590715 right? well i did that but im not seeing that number come up just my old roms
#2614
i think i figured it out i added the xml with all the other then went and opened up the bin and then went to openwith ecu flash and saved it as my name and went and exited it all and re-opened it and everythings there now...i hope that did it seems like it did. thanks for your help i really appreciate it
#2615
W/ regard to ECU controlled boost.. i found the curve i like with the WGDC map (67%)... now i'm noticing under partial throttle and @100% TPS.. the turbo spools and once it reaches a peak boost for whatever throttle % i'm at i can hear a rapid pulsating hissing sound... almost like the wastegate it rapidly opening and closing rather then just staying open and maintaining the current boost pressure... from a look at my gauge pressure it stays constant... I noticed this occuring when i began testing for my boost curve.. with the WGDC set to 0 and BEC all set to 0.. the car runs off the wastegate spring roughly 12 psi and doesnt make the same sound under partial or full throttle once it peaks.... once the WGDC was set to a value that created a boost pressure above the spring rate (~12psi) and the BEC table still 0 it began doing this...
is this because i am not running 100% WGDC in any cell of my map like i was on a MBC? or is the BEC interval to low.. mine is set to 1.. and it is causing the ecu to correct boost levels too often?
by design my boost values peak at about 21 psi and taper down to 17.5-18 psi at redline? am i stressing the turbo too much and that is why its pulsating.... The car is showing no hesitation while the turbo goes through this cycle.. so if i am losing power it's definitely not noticeable.. my biggest fear is that the turbo is dieing... I have no indication of knock.. timing looks good and my afr's are all constant..
#2616
#2620
#2622
#2623
#2624
