TephraMod V7
Old Sep 24, 2012 | 10:33 AM
  #2731
90zcrex's Avatar
Hey everyone, I'm currently switching over to tephra and was just wondering,
I have a usdm evo 9 and will be using 88590715. My mods are very minimal as of now (intake/Exhaust) running on stock tune.
Are the fuel/ignition maps in the Tephra rom an ok starting point to start tuning?
Also I was looking the in tephra rom and can't seem to find where to disable the immobilizer code? (would like it disabled for alarm system/remote start)
Thanks for all your help in advance.
Old Sep 24, 2012 | 11:46 AM
  #2732
ReaperX's Avatar
My suggestion to you, tune your stock rom first, then transfer your maps to V7. It will require more tweaking to dial it in on V7 after the transfer as well.
Old Sep 24, 2012 | 02:49 PM
  #2733
steven121's Avatar
where exactly do you add the evoscan xml at?
Did this rom recently change? not used to all the new maps last time I used the tephra and tuned it was back in 2010-2011?
is this the updated version thats fixed?
Old Sep 24, 2012 | 03:39 PM
  #2734
Raptord's Avatar
xml goes in documents/evoscan/datasettings/Mitsubishi MUTII EFI.xml for evoscan 2.9
Old Sep 29, 2012 | 10:23 AM
  #2735
PL_MR's Avatar
I have Evo6 USDM with intake and exhaust me too on stock tune, I want to swap to V7(before to upgrade some parts and tune), as I see, they only thing I would have to modify is for the boost part that seems empty, otherwise, everything should work normally?
And about the rear O2 Simulator, I have read thread on it but not really sure to understand for what it is really for. It's just for the CEL? when I will swap a WBO2, I tought I have to plug it in the rear O2 plug?
Thanks!
Old Oct 3, 2012 | 10:23 PM
  #2736
steven121's Avatar
Tephra questions
Searched and same answer
If you copy everything over some of the tables wont match up so trying to figure out how to work that
for example in the stepper table will be completly off in my stock rom it reads throttle position, and the tephra reads coolant temp for one of the axis, not to mention if you edit the map definition you can change the tables without changing the address to link it but is the stock rom almost the same as the tephra?
or would you just copy your imbolizer over and just tune from there?
ok little confused I have a 2003 lancer evo 8 with a sunroof if that helps determine the model
should i be using 94170715 or 96530706
Old Oct 10, 2012 | 09:18 AM
  #2737
Yiyo's Avatar
Im trying to add the TephraMod V7 on my car wichone I need ? I have a EVO 9 MR and the ROM is 88590015. I try with the 88590715 but the car did not start. I copy paste everything from current ROM???
Old Oct 10, 2012 | 09:22 AM
  #2738
eric06ix's Avatar
Sounds like you didn't copy the immobilizer data over.
Old Oct 10, 2012 | 09:31 AM
  #2739
Yiyo's Avatar
Yes I did
Old Oct 10, 2012 | 09:42 AM
  #2740
Yiyo's Avatar
That was the first stuff I change. Beside the timming map, fuel map, boost stuff etc What else I need to change because I move all from my current one to the tephra?
Old Oct 10, 2012 | 10:56 AM
  #2741
timmiii's Avatar
I had trouble starting my car too (Evo 9 MR with same ROM ID) at one point because I enabled the alt map settings in the Tephra Options list. Once I disabled it I reflashed my ECU and my car started right up. Still trying to figure out what's going on with that one...
Old Oct 10, 2012 | 11:31 AM
  #2742
Yiyo's Avatar
Thx I will check that today
Old Oct 10, 2012 | 04:59 PM
  #2743
PL_MR's Avatar
I have Evo 9 MR too and I switch to Tephra this weekend with the MAF.
It works great.
I have change the immobilizer, enter the code for the load or psi option for the boost (i choose load), copy the base load boost I have in my stock room into the new one (I copy the low gear for 1 to 3 gear and the high gear for 4 to 6 gear).
After, there was 2 wrong adress, I change them for the same that in the stock rom values (Did that for Accel Enrich and Max total upward wdc correction).
I also change the 0 for a 2 in the rom definition name to get the live mapping.
Old Oct 22, 2012 | 02:48 AM
  #2744
SpinALL4s's Avatar
i'm having problems keeping tephra v7 in my Evo 9 ecu, every time i load it then read, then read it's there but after a bit of time it gets lost. i'll read the ecu a couple days later after not driving it and it's gone. has anyone had this problem?
PS i'm switching to SD, ID2000 with E85
Old Oct 22, 2012 | 05:21 AM
  #2745
domyz's Avatar
How is it gone... Not reading at all ?
Do you use the same computer ?
Did you try a fresh install of Ecuflash, tephra v7 and definitions.
The Ecu uses a dead memory (ROM) to store data so unless someone flash it over, it doesn't get erased and doesn't need battery to keep ROM data. Maybe your ECU is bad, but this is very rare.
Quick Reply: TephraMod V7
