TephraMod V7
Old Jan 3, 2013 | 08:59 AM
  #2806
Tmosser's Avatar
Yeah im looking for option 1.
edit I just downloaded all of them through the pack and got it. Thanks!
Old Jan 3, 2013 | 10:10 AM
  #2807
Tmosser's Avatar
Lol.. Now i can't get map translator to download.
Old Jan 4, 2013 | 08:26 PM
  #2808
yukbumer's Avatar
hey everyone ive recently upgraded my ecu from an evo 5 to an evo 7 and put tephra mods v7 on it, everything is going fine and car drives pretty good but i cant figure out why my launch control wont engage???
for test purposes i set the min tps to 1% and 7mph for the vehicle speed and the stationary limit to 2500, still nothing
also i wired up a haltech 3bar map sensor to pin 73 and tried starting the car with the sd rom but it just wouldnt start? i was using the gm scaling
anything would be great cheers
Old Jan 15, 2013 | 03:42 PM
  #2809
glitch_tt's Avatar
Guys I have donated to the tephra v7 cause can some please send me the 90550001 files?
I tried to PM tephra but his inbox is maxed.
Thanks in advance
Old Jan 15, 2013 | 09:26 PM
  #2810
blackvr's Avatar
Hope one of the guys in this thread can point me in the right direction. I have an ASpec Evo 9 GSR that has the dreaded P0141 rear O2 sensor Heater circuit tripping a CEL. The ecu has standard the 88580013 rom. So I thought I would bypass all that nonsense and flash in the Tephra V7 88580714 rom. It appears to inherit the 88580014 xml definitions.
So the rear O2 sensor simulation has been enabled, and the CEL for that P0141 code still comes on . Any ideas where I head now ?
Also, the intercooler spray functions dont appear in bold .. have I got a dodgy XML ?
Cheers Mike
Old Jan 16, 2013 | 04:27 AM
  #2811
gktune's Avatar
Hi tephra
I am after a XML file to suit 98640014 JDM spec Evo 7. i am very interested i doing mafless tuning for this customer.
I am of course happy to pay you for any advise and files provided.
This vehicle has had an aftermarket ecu fitted , which he is unhappy with and i mentioned to him i may be able to give a more stable and reliable tune with the std ecu.
Any advise appreciated
Old Jan 16, 2013 | 05:11 AM
  #2812
todd6027's Avatar
attached theres no sd rom availble for that id
File Type: zip
Old Jan 19, 2013 | 10:38 PM
  #2813
domyz's Avatar
delete
Old Jan 20, 2013 | 05:27 PM
  #2814
prowakeskater's Avatar
guys im having a problem- Im trying to use 88590715 but it keeps reverting itself to a normal rom.
after I restart my computer and load the rom, all tephra options disappear and it looks like a regular *** rom.
anyone experience this?
Old Jan 20, 2013 | 06:59 PM
  #2815
domyz's Avatar
Is the flash successful?
^Do not transfer Ecu ID to the tephra ROM..
Old Jan 21, 2013 | 10:24 AM
  #2816
nice, I reverted the ECU ID back, saved, closed, reopened and voila!
thanks!
Old Jan 21, 2013 | 01:02 PM
  #2817
coltcztowner's Avatar
Can you help me find someone who has the maps Sync Load Accel ,Async TPS Accel Enrichment
for the 88580714 ROM
Old Jan 23, 2013 | 08:03 AM
  #2818
ISCV maps are not displaying correctly for 8859
can someone find the fault in the code
Old Jan 23, 2013 | 08:15 AM
  #2819
Raptord's Avatar
You need to add elements="8" to both engine temp tables:
Code:
<table name="Desired ISCV intial step position with AC off-Drive" category="Idle" address="3d38" type="2D" scaling="ISCVSteps">
		<table name="Engine Temp" address="70c2" type="Y Axis" elements="8" scaling="Temp"/>
	</table>
	<table name="Desired ISCV intial step position with AC on-Neutral" category="Idle" address="3d4c" type="2D" scaling="ISCVSteps">
	</table>
Old Jan 23, 2013 | 09:21 AM
  #2820
thank you thank you thank you
Quick Reply: TephraMod V7
