TephraMod V7
Old Feb 19, 2013 | 08:02 PM
  #2851
EvoIXPilot's Avatar
Hello. I'm currently using the T7 94170715 Rom. I'm about to install a Omni sensor. Does this Rom already have the required xml edits done or do I still need to follow the instructions to insert the xml script?
Old Feb 20, 2013 | 07:06 AM
  #2852
glitch_tt's Avatar
Has anyone had problems boosting over 30 psi with the v7 maps? I have having break up issues.
Can anyone assist me on this?
Old Feb 21, 2013 | 04:13 AM
  #2853
glitch_tt's Avatar
Never mind guys I found the problem....
BAD PLUGS!!!!!!
Old Feb 21, 2013 | 04:35 AM
  #2854
Howulikemyevo's Avatar
Thanks for the info.
Old Feb 25, 2013 | 11:35 AM
  #2855
corey121389's Avatar
Originally Posted by tephra
big map translator:
For excel 2007 and above
bigmap translator
jw i cant pull this link up it says its not available, JUST DOWNLOADED V7 TRYING TO MOVE ALL MY STUFF OVER AND I LIKE TO HAVE THE TRANSLATOR TO MAKE THIS EASIER... SORRY I AM NEW TO THIS
THANKS FOR ANY HELP U BE-ABLE TO GIVE
Old Feb 26, 2013 | 07:59 PM
  #2856
07EvoIX's Avatar
please check out post 3. it would be good if people read beyond the first post or 2.
cheers
Old Mar 5, 2013 | 03:36 PM
  #2857
intj123's Avatar
This seems like an awsome piece of work, probably wont try it for a little while though, I just flashed my ecu earlier today. I'm particularly interested in the gear controlled boost.
Old Mar 5, 2013 | 05:18 PM
  #2858
01sporty's Avatar
Trying to change map scaling to omni 4 bar. I edit the map save it get back into it and bam it's back to kavlico 3.5 map sensor!!! Anybody have an idea I've tried pushing apply and then save and no dice. I'm on rom 94100715.
Old Mar 6, 2013 | 09:09 AM
  #2859
unihappytime's Avatar
I have downloaded these, see if the help
File Type: zip
Old Mar 13, 2013 | 12:45 AM
  #2860
Lmodel's Avatar
For those that have the V7 roms for your ride, do continue to donate for a good clause.
For those that doesn't, I doubt there will be any more releases to support other roms since the last release was like ages ago..
Old Mar 21, 2013 | 07:30 AM
  #2861
mdsevo06's Avatar
I've been on SD for over 3 years now and receicently did a valve job due to blown HG. We remove the EGR while at the same time and now it will buck (go rich, lack of ignition) on light decel (not full lift) or cruise with no load, seems to be in closed loop. Is there a patch when removing the EGR, or is there a place to adjust for light load and decel?
Old Mar 21, 2013 | 07:34 AM
  #2862
And's Avatar
And
have you zero'd out the egr tables?
Old Mar 21, 2013 | 07:49 AM
  #2863
mdsevo06's Avatar
I check this to make sure there zero'd.
Thanks
Old Mar 26, 2013 | 09:41 AM
  #2864
glitch_tt's Avatar
Guys i am on 90550001 v7 can you tell me what is the SD replacement ROM and where can I find it
Thanks in advance
Old Mar 26, 2013 | 11:18 AM
  #2865
evo8426's Avatar
Thanks in advance
http://www.geekmapped.com/forums/showthread.php?t=1178
Quick Reply: TephraMod V7
