TephraMod V7
#2911
thanks for all the infos and corrections
I don't have anything else sorry, I'm not a "tuner" like all you evo gurus here on evolutionm
I was left with some problems after a paid tune and thx to merlin guide and everyone on evolutionm I finally fixed them
#2912
My 05 uses the 96940011 rom so i loaded the 96530706 v7 rom that's suggested from the 1st post of this thread to be used by all the USDM cars. I changed the immobilizer code to match what is in my 96940011 rom and my car isn't starting, it just cranks. Ive tried looking for a solution in the billion pages of this thread but can't find the fix. Does anyone know what the fix is?
Thanks
Thanks
#2913
Thanks
Thanks
#2915
Thanks
#2917
Have someone experienced a very rich AFR right after a cold start with 88580714? In the 9.8:1 range for 30 seconds or more. But if I move the car immediately the AFR goes to 12.5:1 that is normal for a cold start.
I've tried lowering the "start enrichment table" (post Crank Enrich Decay and Post Crank Enrich %) in the cold start area without effects.
#2919
Can you guys give an ETA when the 8858 updated XML definitions package would be released? Perhaps start a completely new thread, I know that the EDM faction would be extremely grateful to get this.
#2920
#2921
*Probably* a couple mor days. I reorganized a lot of stuff including some of the Evo base file. If you only really use 8858 it's good but 8859 won't exactly follow suit. I've gone a tad personal in organizing but nevertheless 10x easier to sort thru. Plus a ton of added updated definitions. I'm holding out for advanced fuel control options
It's really aimed at v7 users 88580714 88582714 88586714 and not so much the 88580014 stuff
#2922
I am learning though and will start to experiment and bugfix at somepoint.
#2923
#2924
I want to use 88591715 SD for a evo IX, what tables do I need to change scaling to OMNI 4 bar, cause that is what I will use. So far I have changed these:
MAP scaling : changed the scaling manually to omni 4 bar
Boost Adder (PSI): PSIa16 OMNI4barMAP
Boost Desired Engine PSI: PSIa8 OMNI4barMAP
Alternate boost desired engine psi
Boost error correction
What other tables scalings needs to be changed?
What is the difference between PSIa8 and PSIa16 btw?
#2925
Hi everyone,
I need some help. The definition file for my JDM Evo7 ROM (98640014) is very poor resulting in incorrect readings when trying to make a log with 23 Psi boost. I have found here that my ROM can be substituted with 90550001 without any problem. Moreover, i read that there is Tephra version for that ROM which I would like to get (buy). Can anyone tell how can i get it?
Thanks
Shota
Thanks
Shota
