TephraMod V7
Old Feb 5, 2016 | 02:26 AM
  #3301
jameswwt's Avatar
Hi Guys,
im planning to switch my Evo 5 ecu with Ceddy features to a Evo 7 or 8 ecu with Tephra features.
Can someone kindly advise me which Ecu (7 or 8) should i go for and which Tephra version is the latest for the both Ecu's?
Lastly, is this an Evo 8 USDM ecu and can it be flash?
Thanks
Old Feb 7, 2016 | 04:51 AM
  #3302
gudmundur's Avatar
Rear O2 heater circuit simulator
First off I have seen a few posts/threads with information on this but for some reason what is mentioned in those doesn't help me with my issue.
I have been trying to get rid of P0141 - rear o2 heater circuit dtc ,
Originally the ECU ID was 88840016 so I used 88580714 tephramod v7 map
These are the steps I took
1. Turned on Tephramod "rear o2 simulator"
2. cleared DTC's - on second startup p0141 came again
3. Turned off FAA bit 2 - cleared DTC's - after 15-20 min of running ECU threw p0125
4. Turned on FAA bit 2 - cleared DTC's - p0125 was not seen but on second startup p0141 cam on again
Am I missing something or shoud it be enought to turn on Tephramod - rear o2 simulator to get rid of p0141 ?
Or should I just mechanically bluff the heater circuit with resistors.
Any help would be greatly appreciated
regards
Gudmundur
Old Feb 7, 2016 | 07:36 PM
  #3303
jameswwt's Avatar
Originally Posted by jameswwt
Hi Guys,
Thanks
Bump...
Thanks
Old Feb 8, 2016 | 03:20 AM
  #3304
jameswwt's Avatar
Hi Guys,
im looking to buy an Evo 8 USDM ECU flashed with latest Tephra V7 feature with Immobilizer deactivated.
Preferred year 2005 onward Ecu and willing to freight to Malaysia.
Thanks
James
Old Feb 9, 2016 | 02:05 AM
  #3305
xnoisex's Avatar
Hello!
Tell me, how do I translate (convert) tephra7 96530706 in the metric system?
Sorry for my english :-)
Old Feb 9, 2016 | 03:56 PM
  #3306
Raptord's Avatar
Originally Posted by xnoisex
Hello!
What do you mean by translating to metric system?
Old Feb 9, 2016 | 08:35 PM
  #3307
xnoisex's Avatar
Mph to Kmh and Farenheit to Celcius.
Old Feb 10, 2016 | 05:27 PM
  #3308
Raptord's Avatar
I've never tried it, but you should be able to edit/create new scalings and just adapt the imperial formulas to get the metric reading instead.
Old Feb 11, 2016 | 01:55 AM
  #3309
xnoisex's Avatar
Thank you! i changed data in xml that i took from evo7base.
Old Feb 13, 2016 | 09:03 AM
  #3310
jameswwt's Avatar
Hi, can anyone here advise the pinout for Jdm Evo 8 Ecu to Evo 6? Is it same as Usdm pinout?
On the SD rom which wires should i tap for the Map & IAT sensor as im currently running on Ceddy with SD feature.
Lastly how to deactivate the Immobilizer on the 8 ecu?
Thanks
Old Feb 17, 2016 | 10:23 AM
  #3311
jameswwt's Avatar
Hi, im looking for Tephra rom + xml with SD/Live Tuning features for my Jdm Evo 7 Ecu.
Will make a donation for the Rom & Xml
Thanks
Old Feb 26, 2016 | 12:56 AM
  #3312
DrBrown's Avatar
This software sounds awesome!!
Made a donation yesterday, waiting for a reply now.
Can't wait to start playing around with it.
Rom is 90550001
Best regards,
Martin
Old Mar 3, 2016 | 04:21 PM
  #3313
danfalcas's Avatar
Rom is 90550001
Best regards,
Martin
I want it too....... but no response from NO ONE
Old Mar 7, 2016 | 11:37 PM
  #3314
saadme's Avatar
Donation made, Im after 90550701 tephra mod. Evo 7.
Thanks!
Old Mar 18, 2016 | 11:05 AM
  #3315
saadme's Avatar
Got it thanks!
Just wondering, is there a speed density and live map version of 9055001?
Thanks!
Quick Reply: TephraMod V7
