TephraMod V7
Old Nov 11, 2021 | 12:39 AM
  #3646
pobedyst's Avatar
Originally Posted by tephra
TephraMod V7
I wrote in a personal message, but your personal messages are full. Hello Friend. I have a client for whom I need to buy Tephra Mod 3, ID of the software downloaded from the car 53610010. What software should I choose for our RallyArt? 53600010 or 53610013?
VIN - JMBSMCY4A9U000226
European market
Old Jan 2, 2022 | 04:50 PM
  #3647
Assault's Avatar
Originally Posted by 3kg
Unfortunately, to my knowledge, nobody has publicly figured out how to tune nor to get ALS working on an E7 ECU/90550001, mods or not.
I spent a lot of time on this a few years back.
I set up a Gopro pointed at the SAS valve and it does indeed open on the 90550001 ROM or any v5/v7 version of it as long as it's all setup right.
Compared to 96260009 ROM (on the same ECU) the ALS on 90550001 doesn't really do much in the way of Anti-Lag (or pops and bangs). 92620009 I can easily get some savage explosions, like a bomb going off, with only flashing the ROM, no hardware or settings changed at all.
So I dived deep into the disassembly comparing the two Roms ALS related coding and there is a difference with the fueling under ALS conditions, and fueling routines overall. The valve control routine is identical, and the fuel injection time in it is identical, but the way the fueling is enacted on in the Evo 7 Rom or any earlier Evo 8 Rom is different and doesnt appear to stay on the same as the later Evo 8 Roms.
I tried making some changes to the 90550701 to see if I could get the fueling to behave the same as 96260709 but I could not, the fueling routines were too different to easily make it work the same.
End result was that I gave up on 90550701 and moved to 96260709 with working ALS and just sorted out the phantom knock issues I was having with this ROM.
Old Apr 3, 2022 | 07:34 AM
  #3648
I<3myevo6's Avatar
Tephra V7 Valet function
Guys I am running a evo 5 with a evo 7 ecu, need help/steps to use the valet feature on Tephra v7.. Even when I clock 100% TPS for the set time the car will still not deactivate valet mode..CEL just keeps blinking randomly..
Note:
-Auto-valet on fresh ignition is on but even if I disable it it does not work
- car runs fine if valet mode is disabled in the mod options table..
Thank you..
Old Apr 3, 2022 | 10:32 PM
  #3649
EMR88's Avatar
Note:
Thank you..
i woyld suggest hook a data logger and watch live data to see what % the TPS is reading and adjust accordingly.
Also, valet mode the CEL is not flashing random, but flashes in a very specific way.
send the file to someone to check
I<3myevo6 (Apr 4, 2022)
Old May 16, 2022 | 01:06 AM
  #3650
Ping 1M's Avatar
Originally Posted by evoscan
@ae92rolla91
which rom id are you after, for any tephra Evo8 donation (recommended $30-$50USD+), I can send out the roms. just send me the receipt if already paid, or send a donation to paypal at evoscan.com and I can send out any of the following roms... email any requests to hamish (at) limitless.co.nz
96260709-TephraMod-V7 PAID Evo8 96260009.zip
90550701-TephraMod-V7 PAID Evo7 90550001.zip
88580714-TephraMod-V7 AUDM Evo 9.zip
88590715-TephraMod-V7 USDM Evo 9.zip
94170715-TephraMod-V7 USDM Evo 8.zip
96530706-TephraMod-V7 AUDM Evo 8.zip
Available XMLs
TephraMOD-88590715-v7.xml
TephraMOD-88591715-v7.xml
TephraMOD-94170715-v7.xml
TephraMOD-94171715-v7.xml
TephraMOD-96530706-v7.xml
TephraMOD-96531706-v7.xml
TephraMOD-96532706-v7.xml
TephraMOD-96533706-v7.xml
94170715-TephraMod-Fix (v7)
94170715-TephraMod-phenem-fix (v7 + Mods Omni 4 Bar MAP)
94171715-TephraMod-phenem-sd-fix (v7 + Mods + Speed Density Omni 4 Bar)
88590715-TephraMod-recompile (v7 + Mods)
88591715-r3compile-scheides-bigric09 (v7 + Mods + Speed Density)
Hello,TephraMOD have a supported JDM evo 9 ID89280002?
Old May 16, 2022 | 02:01 AM
  #3651
I<3myevo6's Avatar
Guys, I am running a Evo 5 with a Evo 7 ECU via a Tephra V7 (90550001), Kindly help me on the below 2 issues:
-> NLTS is not working
- If turned "on" I am hitting a weird rpm cut at 5-6K RPM, car work fine if NLTS is turned off
- Have wired the grounded clutch switch wire to pin 43 of the ECU
-> Valet does not work on fresh ignition
- If valet function is turned on for fresh ignition the car is always on the set rpm limit(valet) unable to get out
- Valet function work fine if refers on fresh ignition is not tuned on
Pls feel free to ping me at sharewithraj at hotmail.com
Old Jun 8, 2022 | 09:37 PM
  #3652
redfield's Avatar
Guys, does tephra answer your mail? i want to get tephra for my evo 8 mr jdm 96260009.
Old Jun 9, 2022 | 07:55 AM
  #3653
EMR88's Avatar
they never replied to me, but i can help you. Drop me a pm
Old Jun 9, 2022 | 04:12 PM
  #3654
redfield's Avatar
ok, thanks. im pm to you.
Old Jun 12, 2022 | 05:45 PM
  #3655
redfield's Avatar
gays? someone can help me with tephra v7 96260009? Tephra dont answer me on email...
Old Jun 20, 2022 | 04:42 PM
  #3656
redfield's Avatar
hi all. I have an evo 4 with ECU evo 8 mp. I have the following problem with tephra 7 96260709. When I just upload the firmware, the car starts and there are no deviations, but it stalls after 15 seconds and will not start again. Further, if the car stands still, everything repeats. There is no such problem with tephra 96530709. Only P0300 appears from errors, but not always. i have gtr 35 coils. dwell settings lika a Mrfred.
Old Jun 22, 2022 | 04:02 PM
  #3657
ZZA's Avatar
ZZA
Swap pin 8 & 22.
Old Jun 22, 2022 | 04:32 PM
  #3658
redfield's Avatar
Hi. I have a ECU for 3 chips, not 4, but I get your point. It's just that if I mixed up the pins, why does everything work without problems on 9653? then it wouldn't work. I took the pinout for ECU 8 MP on it, these are 20 and 21 pins.
Old Jun 23, 2022 | 09:24 PM
  #3659
ZZA's Avatar
ZZA
I've always had good luck with 9653 & 9417 in my Evo 6 with 8 ecu. If 9653 works just use that.
Old Jun 23, 2022 | 09:46 PM
  #3660
redfield's Avatar
I already use 9653, it's just that it's not for the waiting version, unlike 9626. At the moment, I tend to think that the problem is somehow related to the ignition, maybe there are some settings in the 9626 firmware that are not in 9653.I already use 9653, it's just that it's not for the JDM version, unlike 9626. At the moment, I tend to think that the problem is somehow related to the ignition, maybe there are some settings in the 9626 firmware that are not in 9653. On this forum, I found similar topics with such problems, the solutions were not described in them.
Quick Reply: TephraMod V7
