TephraMod V7
Old Oct 16, 2009 | 05:19 PM
  #391
phenem's Avatar
Originally Posted by Jack_of_Trades
Yeah, I'm finishing up my XML as we speak, once I'm done I'll email you a copy.
Perfect I will wait for that, that way I can update the files all at once. I have confirmation that Live Mapping is working too! I will be posting that up ASAP with everything else....
Old Oct 16, 2009 | 05:32 PM
  #392
binky's Avatar
Good work guys
Tephra- expect a donation after I load this bad boy up
-Bink
Old Oct 17, 2009 | 12:51 AM
  #393
Jack_of_Trades's Avatar
Attached is my organization of the maps/tables for v7. I removed the inheritance of 96530006 and Evo7base XML's so this XML file is 100% independent. If you change something in this XML, it ONLY effects this XML, no others The PSI based boost control tables have the scalings already set for the JDM/Evo X MAP Sensor, you just need to switch over the tables in the 'Boost Control 'TYPE' section for either LOAD or PSI boost control.
I only added the tables I could find. If anyone has more tables that I can add, please PM me.
CLICK HERE TO DOWNLOAD XML FILE!
Old Oct 17, 2009 | 01:57 AM
  #394
rolly1818's Avatar
Registered User
good work, the only thing i can think about is DMA
Old Oct 17, 2009 | 06:14 AM
  #395
evovette's Avatar
JoT I loaded that into a fresh instance of evoscan and it doesnt look anything like that. All I did was drop that XML into a virgin copy of evoscan. open the 36530706 file from phenoms first post and no go. Any ideas?
Old Oct 17, 2009 | 06:50 AM
  #396
chmodlf's Avatar
I think you meant ecuflash. I have the same issue. It seems like it is still inheriting the other xml and is not independent.
Old Oct 17, 2009 | 07:05 AM
  #397
evovette's Avatar
yes Ecuflash!
Old Oct 17, 2009 | 07:22 AM
  #398
phenem's Avatar
JoT, I only see a Tephra XML not an entire XML definition?
Old Oct 17, 2009 | 08:03 AM
  #399
mguyott3's Avatar
good work
Old Oct 17, 2009 | 08:29 AM
  #400
gear head's Avatar
It looks like it still inherits the 96530006, but not the evo7base which it still needs.
Old Oct 17, 2009 | 11:44 AM
  #401
NineWorks's Avatar
Originally Posted by tephra
ROMS
96530706 TESTED by Phenem,
88580714 TESTED by Me,
941700XX, 969600XX, 964200XX??? - See Phemen's first reply down below!!
88590015, 90550001, 88580014, 88570008, 96260009 + MORE COMING SOON!!!
Hi David,
Please let us know what is your plan for 88840017 version 7 ?
As far as I can see, there is not any compatible Rom...
Cheers
Old Oct 17, 2009 | 12:00 PM
  #402
That XML file should be the only XMl file required now. I'll look into why its not showing up right, it was late lol.
It shouldn't need to inherit ANY other XML's, all data was converted into one XML. The XML files don't NEED to inherit other XML's, they just do because they found it easier to put the most common maps in one XML file and just referenced off of them. It shouldn't be inheriting any other XML files, if you look at the EDIT window for any map/table it will only have a tab for 96530706, not 96530006 or evo7base.
Are you guys completely replacing the original Tephra 96530706 v7 XML file with this one or copy/pasting? You need to completely replace the original tephra v7 XML with mine.
EDIT: stupid me uploaded the wrong XML file! lol Gimme a sec and I'll post the new one.
Old Oct 17, 2009 | 12:07 PM
  #403
Here is the one I INTENEDED to upload:
File Type: zip
Old Oct 17, 2009 | 12:23 PM
  #404
RoadSpike's Avatar
The download isn't complete its probably an old version or something that still relies on other files. I did replace the old files with yours and lost about 80% of the tables in the process.
It only seems to have the tephra v7 mods in this xml and nothing else.
Old Oct 17, 2009 | 01:33 PM
  #405
Redownload it, I had uploaded the wrong file. You'll know its my newer version if there are descriptions on a bunch of the 1D tables explaining what the adjustments are for.
Quick Reply: TephraMod V7
