TephraMod V7
#481
Where do I put in my Injector scaling base? V7 does not have the same table.
Thanks.
Paul
Never mind.....I found it.....not in the place I thought it was.
Thanks.
Paul
#483
#484
Never mind....just change the min and max scaling on timing to -55 and 55.
#486
#487
#488
#489
The immobilizer bit is wrong defined in most XMLs it is bit3 (4th bit from bottom) not bit2 (3rd bit from bottom).
I changed it on the wiki: http://evoecu.logic.net/wiki/Periphery_Configuration
#490
TTP, I was speaking of the actuall HEx used to allow the immobiliser to work. I have had no problems with the Periphery trick, but the standard V7 has 0040 in the Immobiliser hex and the should be changed to 0058 for the 05 evo. The 04 may have something else.
#491
The reason is:
Any idea what people are turning off then with the incorrect address?
#492
#493
I have found something about front and rear heater bank 2 on a v6 rom. but on a evo? maybe some solenoids.
What pins numbers do v6 models have with evo8-style ecu plugs for o2 heater?
#494
My car is an 04 and used 0x0055 for the immobilizer hex. BlackE try downloading the newest version of V7 a couple pages back. It has the immobilizer hex in it. The V7 on page 1 of this thread does not.
Edit: I lied the second post in this thread has in fact been updated.
#495
I think he posted instructions here https://www.evolutionm.net/forums/ec...-xls-file.html
