TephraMod V7
#496
It's pretty simple. You'll need to copy your current timing map onto the top part, and copy the rpm and load cells as well. The bottom part will now show you what your timing map should look like on the BIG Maps tables on EvoScan, so copy and paste. Then moving on to the fuel map, copy your current fuel map. Copy the rpm and load cells, and then at the very bottom of the first chart theres a '1000000' cell which is grey, you will need to copy that and then paste it on the rpm/load cells that you aren't using. Hopefully you understood that lol..
#497
Look at the blobbits tables for Peripheries. And you guys are wrong about immob disable, that would be 0x56D2
Periphery0
0x56DA: Stock
0x58DA: Disable EGR advance, Disable warmup retard
Periphery2
0xEFDF: Stock
0xEDDF: Disable EGR test
Map Fault Trig Max:
4.82: USDM MAP
4.92: JDM MAP
Periphery0
0x56DA: Stock
Periphery2
0xEFDF: Stock
Map Fault Trig Max:
4.82: USDM MAP
4.92: JDM MAP
"Change the "MAP Fault Trig: Mid VE Max #1" value from 4.80 to 4.90."
Just trying to confirm which is correct.
TIA
#498
The reason is:
The immobilizer bit is wrong defined in most XMLs it is bit3 (4th bit from bottom) not bit2 (3rd bit from bottom).
I changed it on the wiki: http://evoecu.logic.net/wiki/Periphery_Configuration
#499
https://www.evolutionm.net/forums/7597107-post2.html
#500
I tried to use the other big map translator, and it didnt exactly interpolate correctly, so spent about an hour last night setting up my big timing map, 1 column at a time... And still not done w/ that map... Still gotta do my fuel too...
#501
Yeah, I fixed the immob. disable bit in the XML a couple of days ago.
#502
I think he meant, that when he opens it up, theres only files, and .xml's, no worksheet... Or atleast, that my issue! DL'ed it several times now...
#503
I havent gotten to the fuel map, but Im sure the instructions you posted, will help me out there...
#504
Read the instructions in the first post guys. It does show up, you have to be in developer mode in ECUFlash. Also in the first post under VERY IMPORTANT it tells you that you have to change the immobilizer hex to match your car for it to work properly. I am not trying to be difficult but ready the post and most of your answers are there.
yeah soory about that^^^^
i downloaded the new XML in the first page and now i got it to work.
Thanks!
#505
no worries... Im not even sure thats what he meant, but I assumed, since I had my issue, that he was having the same... I open it up, and theres no worksheet, just shows me a bunch of files, etc. I can open the "other" BMT (big map trans.) and it shows me "the worksheet"...
https://www.evolutionm.net/forums/7597112-post3.html
Do you have Excel 2007?
#506
Are you using the download in this post:
#508
I was unaware that I needed to have 2007... Edit: I dont know how I missed the whole 2007 and above... All I saw was BIG MAP TRANSLATOR... lol
I think Im running 2000... Im assuming this is my prob.
It came w/ my microsoft office disc... Is there any way of upgrading excell, w/out having to purchase a new MO?
I get the same thing fast freddie is getting...
