TephraMod V7
Old Oct 21, 2009 | 11:48 AM
  #601
nonschlont's Avatar
Originally Posted by recompile
Probably forgot to add the scale
<scaling name="Percent (128)" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
I'll double check that. Thank you!
tested: 3D maps, valet, alt. maps, knock cell, big maps, all good!
Edit: that was it! Thank you!
Old Oct 21, 2009 | 01:19 PM
  #602
Chris Moore's Avatar
Originally Posted by tephra
you can just change the names in V5.10 to something else..
Could it have something to do with mrfreds load based boost patch installed?
Old Oct 21, 2009 | 01:30 PM
  #603
phenem's Avatar
Originally Posted by 95630706
I apologize if I missed it, but if I wait patiently a 96530706 MAT patched version will be coming?
I couldn't find just the 96530006 patch to add to Phenom's ROM in the MAT thread, only a pre-patched, pre V7 ROM.
Thanks
Email me offline: phenem at gmail dot com
Old Oct 21, 2009 | 01:45 PM
  #604
evovette's Avatar
Just to let everyone know V7 Evo 8 rom passes Mass inspection without issue.
Old Oct 21, 2009 | 02:21 PM
  #605
Jim in Tucson's Avatar
Originally Posted by nano
Make sure its set to Rainbow color map. I did that and it was still on Coldfire and looked like crap!
THANKS! That did it.
Old Oct 21, 2009 | 02:23 PM
  #606
BoostWhore's Avatar
I feel stupid but I thought i downloaded v7 how do i actually use it? IF i try and open it in ecuflash it doesnt work?
Old Oct 21, 2009 | 02:45 PM
  #607
nonschlont's Avatar
extract all of the files, the .xml / 's, go into your rometadata file folder, and the BIN file, you (R) click on it, "copy" it, open up ecuflash, click on the file folder, which brings you to all of the roms, then click "organize" (or just (r) click and click paste, then that rom will be able to be opened.
Its not working, (most likely) cause youre not adding the .xml's properly...
You need to go through the comp./program files/ecuflash/rometadata etc. If you just open up the file folder on your desktop, it will NOT work.
Old Oct 21, 2009 | 03:17 PM
  #608
tephra's Avatar
Originally Posted by fostytou
No, it was the after patch, and it is definitely NOT working. It is hunting for the correct AFR, but the trims are WAY off....
the rear02 simulator is already included in V7, so you just need to worry about the closed loop part of MrFreds patch..
Old Oct 21, 2009 | 03:19 PM
  #609
BoostWhore's Avatar
thanks for your time... I take it I would have to copy my existing stock map over to it also?
just noticed I have to use one that has the same internal id right?
mines 88590015 which i only see 14 thanks
Old Oct 21, 2009 | 03:34 PM
  #610
Jack_of_Trades's Avatar
Question for you guys. Which MAF tables are no longer used when Speed Density is implemented? I know the following won't be used:
MAF Size
MAF Scaling
MAF Compensation
MAF Sensor Filtering
I assume....
Relative Air Density vs Temp for Airflow/Hz
Airflow/Hz Baro and Air Temp Compensation
...wouldn't be used either but I'm not sure. Any other tables no longer used with SD?? Thanks guys!
Old Oct 21, 2009 | 03:36 PM
  #611
Creamo3's Avatar
Originally Posted by Jack_of_Trades
Once we launch the revised XML's, they will already hav the MAT tables pre-loaded as well as a ton of other patch tables that get commonly used
Is this true for the SD XML's as well? I noticed the MAT tables looked way different than my 94170015 SD ROM, but figured it was an attribute of the new XML/ROM. I only copied RPM VE and MAP VE tables and didn't touch the MAT tables. I'll shoot phenem an email to update his first post to add that detail if it needs to be changed for the SD guys.
  #612
nonschlont's Avatar
u wanna DL the 88590715 version (w/ MAF), as this is the "tephra rom" for our rom ID (88590015) The rom w/ 88591715 is the "SD Rom"
R3compile hooked us up w/ that 1. Thank You R3compile!
Old Oct 21, 2009 | 04:15 PM
  #613
phenem's Avatar
Please do I am not sure what you mean here, you have to change your VE vs. Load and VE vs. RPM to match your SD settings.
The MAT table is setup to pull temperature from the fuel sensor and you would need to change a table to have it pull from the GM IAT and adjust the MAT table appropriatly. Look at the jscbanks thread on SD: https://www.evolutionm.net/forums/ec...y-patches.html
Old Oct 21, 2009 | 05:36 PM
  #614
rolly1818's Avatar
Registered User
guys, i am gonna use 9653 on a JDM 8, the rear O2 needs to be disabled, but i rather not do it by bis since it affects logging the fuel trims.
is tephra's mod: rear O2 simulator applicable here? work without any CELs?
Old Oct 21, 2009 | 05:39 PM
  #615
tephra's Avatar
you will probably still get a heater code...
is this a twin solenoid car? ie 9626000X?
Quick Reply: TephraMod V7
