TephraMod V7
Old Oct 23, 2009 | 11:11 PM
  #691
Slo_crx1's Avatar
Originally Posted by Oettinger
Your problem is the BOV, change to recirculated bov or replace your bov for one new.
Actually no it's not, as currently I'm running the speed density patch with no MAF. It only drops idle under load from the climate control fan, same as it would for when the A/C is on. I'm pretty sure the last time I had this issue I adjusted the A/C idle and the problem went away.
Old Oct 24, 2009 | 12:10 AM
  #692
kaj's Avatar
kaj
Originally Posted by kaj
do i still disable the immobilizer in the same periphery as with 5.x? if so, can someone PM me..? i kinda forgot. it's been a long time.
i have periphery 2 set to 0001. correct?
Old Oct 24, 2009 | 12:13 AM
  #693
kaj's Avatar
kaj
so for 88590015 i am to use 88590715, seeing how i use MAF and have NO clue what "live mapping" is?
Old Oct 24, 2009 | 12:33 AM
  #694
kaj's Avatar
kaj
Originally Posted by phenem
Option 2 - Thanks to recompile 88590715 (v7 + Mods) - Download | Mirror
  • Setup for JDM MAP and PSI based boost control (mrfred)
  • WGDC Correction Interval set to 1 (Stock = 10)
  • Max Total Upward WGDC Correction @ 100% TPS set to 0 (Stock = 10)
  • EGR System Disabled (mrfred)
  • Max Timing Retard set to -20 degrees (tephra)
  • FAA bit.10 disabled ("weird unknown" timing pull at cruise)
  • FAA bit.09 disabled (cat-warmup ignition retard)
  • FBA bit.00 disabled (lean spool)
  • FCA bit.09 disabled (EGR Test)
  • OBD Inspection set to Pass all tests (acamus)
  • Rear O2 Heater patch applied (mrfred)
  • Fuel Cut Load Limit x2 and set to 300 (mrfred)
so i DL'ed the zip file. i ended up with like two or three different xml files.. it's hard to read either 'cause they look like this:
i have these:
88590015_r3compile_20091010
evo9base_r3compile_20091010
TephraMOD-88590715-v7
which do i use? i keep getting errors that they are "unrecognized roms". it's been a while since i installed 5.1 and set it all up. what am i missing???
Old Oct 24, 2009 | 01:15 AM
  #695
GotWheelHop's Avatar
Go to my second post and click on the link for the jcsbanks SD post, mrfred lays out how to do it in that post. It will be the same for that ROM.
Was the table to change the value from 0x03 -> 0x0E removed?
In my 94170015 SD ROM I can find it in the SD Programming menu, between SD Disable Baro Error, and SD MAT Scaling. I can't find it in the new SD Programming menu with the 96533706 ROM anywhere.
Am I just blind, or is it actually not present?? Thanks.
Old Oct 24, 2009 | 01:21 AM
  #696
ohhgyeahfasho's Avatar
i have these:
All 3 of those XML's needs to be placed into your 'rommetadata\mitsubishi\evo' folder. They all will be used once you open the 88590715 V7 rom. You will also need to have Ecuflash version 1.41 or higher.
Old Oct 24, 2009 | 03:18 AM
  #697
Oettinger's Avatar
Perfect! See screw SAS in throttle body and with ecuflash see rpm arround 900-950rpm.
Old Oct 24, 2009 | 04:56 AM
  #698
recompile's Avatar
i have these:
If Notepad ever displays a text file like that, it's because it was saved in the Unix-standard with only a carriage return at the end of each line (as opposed to the Windows-standard which is carriage return + line feed)
Opening the file in Wordpad is a workaround for this problem.
As far as which XML, as stated earlier, make sure all 3 go into your folder, and also make sure you're using the latest version of EcuFlash.
Old Oct 24, 2009 | 05:35 AM
  #699
tephra's Avatar
recompile did you remove the rear02 signal simulator? and also the airflow stuff as well (since its already in V7?
Old Oct 24, 2009 | 05:48 AM
  #700
recompile's Avatar
I removed the redundant airflow rate calc patch, but I left the rear 02 heater simulator because I thought your patch was for rear 02 signal only, no?
Old Oct 24, 2009 | 06:09 AM
  #701
recompile's Avatar
Originally Posted by Chukee_R
I don't see anything about setting a specific "Immobilizer Hex" for an Evo IX, so can someone tell me if this is correct? My code of 4301 is correct, but I just want to make sure the Hex (0068) is right.
0068 should be right for USDM IX
Old Oct 24, 2009 | 06:14 AM
  #702
tephra's Avatar
yup signal only
ok on the heater
Old Oct 24, 2009 | 06:42 AM
  #703
Creamo3's Avatar
It's not present, not sure why it was removed??
Old Oct 24, 2009 | 07:16 AM
  #704
Slo_crx1's Avatar
Already did that 2 days ago just to make sure. It's something to physically do with the IACV when there's an electrical load, similar to the air conditioning being turned on and idle raises...I'm going to look into this more today.
Old Oct 24, 2009 | 08:36 AM
  #705
Jack_of_Trades's Avatar
Maybe because the load switching point set in the ECU isn't being reached with your SD setup? Your load values that occur when your lights/AC/accessories turn on might be lower than it normally would have been with the stock MAF setup.
Quick Reply: TephraMod V7
