TephraMod V7
#856
I haven't tried logging MAT with v7 yet. I'll give it a try tomorrow to see if it is ok.
Edit: Actually, I take that back...I have been on V7 for a while and MAT logs fine. I just recently went to V7 with bigmaps, but haven't logged MAT with that yet. Have you applied the MAT patch?
EvoScan XML formula that I've been using is:
<DataListItem DataLog="Y" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="09" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-40" GaugeMax="300" ChartMin="-40" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
#857
Hi guys,
I made a special version of my XLS maps rescaler for V7...I just publish it in the original thread...
I need time to try the V7 on my ECU so the XLS has not been tried already... It should be safe but please proceed carefully!!!! (Yes this is a WARNING ;-)
Hope this help!
Cheers,
C>
Hope this help!
Cheers,
C>
#858
Hmm, is the rpm/speed to gear values thats already on the V7 rom for Evo 9's for a 5 speed? And if not, then does anyone have a rpm/speed to gear values for Evo9 5speed? For some reason when I log 'Gears' in EvoScan it's showing as "Infinite", I gotta look into it more but been busy with school. And also in the Gear '0', do I leave it at the original setting of 2899.78 or just zero it out? As for the MAF IAT WGDCC, I zero'ed it out. Question is, is it really needed? Thanks!
#859
Post the entire table for your MAT scaling and I will check against mine after I do some logging.
#860
Does not seem to work as "stock"... Shows odd LoadError and WGDC Correction values. I wonder if mrfred's mod https://www.evolutionm.net/forums/ec...trol-mods.html is going to help ?
The "Load Error RAM Address" and "Load Error RAM Address in Load Error Table" will both read: 69CA. Change both to 6EE2 (again, you'll need to enter it as 0x....)
#861
I think I remember reading somewhere that someone was having a similar problem where it starting running richer at colder temps. It turned out that his MAT scaling was off (the part that doesn't show in your screenshot). I think one of the threads with the MAT scaling had incorrect values maybe.
#862
So ive been trying to figure out how to set my rpm/speed to gear values for my 2g dsm fwd. Ive tried logging gear but i only get error messages when trying to review my log. Is there another way to calculate what the values should be?
#863
This seems like a silly question, but I thought the 1byte load value (MUT41) was corrected (temp+baro). Is it? In my logs it's looks at least has high as what might be load_raw. Actually, it looks WAY too high -- ~300 on a basically stock evo 8 at 6000' elevation.
I'm using the default scaling factor (1.2).
d
d
#864
d
d
#865
#866
See post #1 for pre-setup MUT's for rpm/speed that the ECU sees (and that you can put into my gear table)
remember you want the medium value... as it does deviate a little...
log and you will see what I mean
#869
Would these MUT values be different from your V6 rom ? I ask because now my gear does not log correctly in Evoscan (it did in V6). Although it seems the rpm/speed still logs correctly.
