TephraMod V7
#976
This isn't a simple 10 second answer, you'll need to do some additional reading.
But, for starters, you'll need to copy the immobilizer code from your original ROM into the Tephra ROM, and also likely retune all your fuel and timing maps (or run the Big Map translator spreadsheet, https://www.evolutionm.net/forums/7597112-post3.html, on your original ROM values to at least get you in the right ballpark).
It would also help if you elaborated exactly what you can't get to work.
ok, so i just remembered that bin files are also rom files :P sorry, my bad.
As son as i get to my laptop i'll try using it.
So i just open the bin file (88080714.bin), fix both fuel and timing maps with the bigmap translator, copy the inmobilizer code from the stock one and upload the rom to an originally 88580014.hex ecu???
What i most want to use is the alternate maps for launch feature and switching fuel maps.
thanks a lot SoCal Rally.
#977
you put tephras bin file in your ecuflash hex file
(the place your flash uploads and downloads to the ecu are)
put the xml in the meta/ rom location.
open your hex files, open the new v7 file, put your old info in the new file.
#978
I have just two more question, why fuel and timing tables are located in tephraV7 list instead on fuel and timing lists???
and, i only have to copy the inmobilizer code, fuel, timing, injector scaling, bla bla bla and upload it in the car's ECU??? (remember it has from factory a 88580014 ROM).
thanks everyone.
#979
You just gotta make sure you have the .xml file(s) in the correct location
#982
I went to get ready to load up Live mapping MAF based ROM into my car yesterday but noticed the NLS rpm drop box wasn't accessible. Had anyone picked up on this and should i just download it again?
Also in the big maps the load column said LOAD (kpa), is that what its just labeled or is it really boost based load which should actually be for SD based and not maf.
#984
#985
I am currently using the new Option 4 96530706 (v7 + Mods) and have verything setup to work of "Load Based Boost" which is working just great on my EDM Evo8.
My Omni 3Bar map sensor had just arrived with the intention of changing over to "PSI Targeted Boost Control" but........
Since we use metric over here, I would like to do it based on "Bar" and not PSI.
Is that option avalibale atm?
Currently being worked on? IS there a ETA for it?
What is involved in doing the conversion from PSI to Bar. I don''t mind doing it myself but I do need pointing in the right direction.
Thx.
Edit: My GM IAT sensor also arrived.
So once i have "BAR Targeted Boost Control" sorted out, I then would like to change over to Speed Density, hopefully also using Bar Boost control and Celsius for IAT's.
Are there any plans for releasing "Metric" Speed Denisty ROM's?
Thx.
#987
This 3rd gear pull was done at 26psi. There is a fuel cut at 6437 RPM. The load is huge. I don't know what is going on
Code:
TPS RPM Battery MAF STFT MTFT HTFT O2 O2_2 IPW IDC WBAF KS AFRMAP LdCalc Ld2Byte 23.14 2156.25 14.08 77 5.98 -2.06 0.1 0.9 0.64 1.79 3.22 11.5 0 14.7 39.92 41.56 24.71 2156.25 14.08 77 5.98 -2.06 0.1 0.92 0.66 2.3 4.2 12 0 14.7 77.42 65.31 33.73 2250 14.08 77 5.98 -2.06 0.1 0.94 0.68 3.84 6.7 12.1 0 12.71 112.36 108.13 79.22 2250 14.08 77 5.98 -2.06 0.1 0.96 0.74 4.35 7.71 11.8 0 13.54 98.91 93.13 100 2250 13.93 77 5.98 -2.06 0.1 0.94 0.8 3.84 7 10.9 0 14.36 89.87 89.69 100 2281.25 14.08 77 5.98 -2.06 0.1 0.9 0.82 3.84 7.1 12.1 0 14.25 89.61 91.56 100 2312.5 14.08 77 5.98 -2.06 0.1 0.9 0.8 3.84 7.3 13 0 14.15 96.16 93.13 100 2343.75 13.93 77 5.98 -2.06 0.1 0.9 0.8 3.84 7.5 13 0 13.84 93.62 94.06 100 2375 14.01 77 5.98 -2.06 0.1 0.92 0.8 4.1 8.11 12.9 0 13.44 98.01 96.25 100 2406.25 14.01 77 5.98 -2.06 0.1 0.92 0.8 4.1 8.32 12.8 0 13.44 98.01 97.81 100 2437.5 14.23 77 5.98 -2.06 0.1 0.92 0.8 4.1 8.43 12.5 0 13.34 97.91 98.75 100 2500 14.15 77 5.98 -2.06 0.1 0.92 0.8 4.35 9.07 12.3 0 13.34 104.52 99.38 100 2531.25 14.15 77 5.98 -2.06 0.1 0.92 0.8 4.35 9.29 0 13.25 103.78 100.31 100 2562.5 14.15 77 5.98 -2.06 0.1 0.94 0.8 4.35 9.41 11.9 0 13.25 103.78 100.63 100 2593.75 14.15 77 5.98 -2.06 0.1 0.94 0.82 4.35 9.63 11.6 0 13.34 104.52 101.88 100 2656.25 14.08 77 5.98 -2.06 0.1 0.92 0.82 4.35 9.75 11.6 0 13.25 103.59 102.5 100 2687.5 14.15 77 5.98 -2.06 0.1 0.92 0.82 4.35 9.86 11.7 0 13.25 103.78 103.44 100 2718.75 14.23 77 5.98 -2.06 0.1 0.92 0.82 4.35 10.09 11.6 0 13.25 103.98 104.69 100 2781.25 14.23 77 5.98 -2.06 0.1 0.94 0.82 4.61 10.8 11.6 0 13.16 109.97 105.63 100 2812.5 14.08 77 5.98 -2.06 0.1 0.94 0.82 4.61 10.92 11.3 0 13.16 109.57 107.5 100 2875 14.15 77 5.98 -2.06 0.1 0.94 0.82 4.61 11.04 11.3 0 13.16 109.77 109.06 100 2906.25 14.15 77 5.98 -2.06 0.1 0.94 0.82 4.61 11.28 11.2 0 13.07 109.01 109.69 100 2968.75 14.08 77 5.98 -2.06 0.1 0.92 0.82 4.86 12.03 11.3 0 13.07 115.48 112.19 100 3000 14.15 77 5.98 -2.06 0.1 0.94 0.82 4.86 12.16 11.3 0 13.07 115.68 113.44 100 3062.5 14.15 77 5.98 -2.06 0.1 0.94 0.82 5.12 13.2 11.3 0 12.89 120.67 115.94 100 3093.75 14.23 77 5.98 -2.06 0.1 0.94 0.82 5.12 13.33 11.3 0 12.98 121.69 119.06 100 3156.25 14.15 77 5.98 -2.06 0.1 0.92 0.82 5.12 13.6 11.1 0 12.98 121.5 121.25 100 3218.75 14.15 77 5.98 -2.06 0.1 0.94 0.82 5.38 14.56 11.3 0 12.98 128.12 123.44 100 3281.25 14.15 77 5.98 -2.06 0.1 0.94 0.82 5.38 14.7 11.3 0 12.98 128.12 125 100 3312.5 14.08 77 5.98 -2.06 0.1 0.92 0.8 5.38 14.98 11.3 0 12.98 127.93 125.63 100 3406.25 14.01 77 5.98 -2.06 0.1 0.92 0.8 5.63 15.99 11.6 0 12.98 134.35 130.94 100 3468.75 14.08 77 5.98 -2.06 0.1 0.92 0.8 5.89 17.02 11.6 0 12.98 141.17 135.63 100 3531.25 14.08 77 5.98 -2.06 0.1 0.92 0.8 6.14 18.24 0 12.98 147.79 139.06 100 3593.75 14.15 77 5.98 -2.06 0.1 0.92 0.8 6.14 18.4 11.5 1 12.98 154.6 142.5 100 3625 14.15 77 5.98 -2.06 0.1 0.92 0.8 6.4 19.67 11.6 1 12.98 154.6 146.56 100 3718.75 14.01 77 5.98 -2.06 0.1 0.94 0.8 6.4 20 11.7 1 12.98 160.83 146.56 100 3781.25 14.08 77 5.98 -2.06 0.1 0.92 0.8 6.4 20.33 11.8 1 12.98 161.03 148.13 100 3875 14.08 77 5.98 -2.06 0.1 0.92 0.78 6.66 21.49 11.7 0 12.89 159.93 151.56 100 3937.5 14.08 77 5.98 -2.06 0.1 0.92 0.78 6.66 22.01 11.9 0 12.89 159.93 153.75 100 4000 14.08 77 5.98 -2.06 0.1 0.92 0.78 6.91 23.22 11.9 0 12.89 166.5 157.81 100 4062.5 14.08 77 5.98 -2.06 0.1 0.92 0.78 7.17 24.64 11.9 0 12.89 173.08 160.94 100 4156.25 14.08 77 5.98 -2.06 0.1 0.92 0.78 7.42 25.91 12 0 12.8 184.96 169.69 100 4250 14.01 75.2 5.98 -2.06 0.1 0.92 0.78 7.94 28.31 12 0 12.63 188.73 177.5 100 4343.75 14.01 75.2 5.98 -2.06 0.1 0.94 0.78 8.45 30.8 11.9 0 12.54 200.27 184.06 100 4406.25 13.93 75.2 5.98 -2.06 0.1 0.94 0.78 8.45 31.46 11.7 0 12.46 205.12 190.31 100 4500 14.01 75.2 5.98 -2.06 0.1 0.94 0.78 8.96 33.83 2 12.54 213.07 199.69 100 4593.75 14.01 75.2 5.98 -2.06 0.1 0.94 0.78 9.47 36.51 11.3 2 12.46 224.38 209.06 100 4687.5 13.86 75.2 5.98 -2.06 0.1 0.94 0.78 9.73 38.25 11.5 1 12.46 236.72 218.13 100 4812.5 13.86 75.2 5.98 -2.06 0.1 0.94 0.78 10.24 41.33 11.2 1 12.46 249.43 230 100 4906.25 13.93 75.2 5.98 -2.06 0.1 0.94 0.78 10.75 44.24 11.1 1 12.54 257.68 241.25 100 5031.25 13.86 75.2 5.98 -2.06 0.1 0.96 0.78 11.78 49.68 11.1 1 11.83 273.11 252.5 100 5125 13.79 75.2 5.98 -2.06 0.1 0.96 0.78 12.29 52.48 10.7 1 12.06 290.49 270.94 100 5250 13.86 75.2 5.98 -2.06 0.1 0.96 0.78 13.06 57.46 10.1 0 12.3 315.19 298.13 100 5375 13.79 75.2 5.98 -2.06 0.1 0.96 0.78 14.08 63.8 10.1 0 12.38 336.03 324.38 100 5500 13.71 75.2 5.98 -2.06 0.1 0.96 0.78 14.85 68.83 10 0 12.38 361.11 347.19 100 5656.25 13.79 75.2 5.98 -2.06 0.1 0.96 0.78 15.36 73.2 10.3 2 12.3 365.2 357.5 100 5812.5 13.64 73.4 5.98 -2.06 0.1 0.96 0.78 15.87 77.71 10.7 2 12.3 377.38 368.75 100 5968.75 13.57 73.4 5.98 -2.06 0.1 0.96 0.76 15.87 80.19 11 2 12.14 378.53 370 100 6125 13.57 73.4 5.98 -2.06 0.1 0.96 0.76 16.38 84.91 11.2 1 11.91 377.42 372.5 100 6281.25 13.57 73.4 5.98 -2.06 0.1 0.96 0.76 16.9 89.76 11.2 1 11.76 378.7 377.5 100 6437.5 13.49 73.4 5.98 -2.06 0.1 0.96 0.76 0 0 11.1 1 11.61 -11.34 365.94 100 5875 13.86 73.4 5.98 -2.06 0.1 0 0.21 6.4 37.33 18.4 1 12.3 183.43 184.69 100 6312.5 13.93 73.4 5.98 -2.06 0.1 0.04 0 1.02 5.68 18.4 0 14.04 23.38 26.88 23.92 6343.75 14.23 77 5.98 -2.06 0.1 0.88 0.66 1.79 9.66 13.9 0 14.04 45.71 46.88 23.53 6468.75 14.08 84.2 5.98 -2.06 0.1 0.06 0.7 1.79 9.61 12.3 0 13.34 56.66 37.5 22.75 6406.25 14.08 89.6 5.98 -2.06 0.1 0.04 0.59 4.1 21.76 15.3 0 11.91 87.02 73.44
#988
#989
