TephraMod V7
Old Nov 9, 2009 | 07:39 AM
  #991
hediki12's Avatar
i dnt now much about using this but mayb your hitting stock fuel cut limit and you need to up it? https://www.evolutionm.net/forums/ec...nge-638-a.html
Old Nov 9, 2009 | 08:04 AM
  #992
fostytou's Avatar
EvoM Community Team
Originally Posted by SeanV
If only everything was that simple.
Sure that works great if you only ever boost 1 bar and/or 2 bar and nothing in between.
No, really... it is that simple (if you passed 7th grade algebra).
Just divide the result of the current calculations by 14.5. There are already about 30 posts in this thread about "converting" to different display methods, but there is no conversion necessary.... it is just how you view the data, and is as simple as changing the equations.
Old Nov 9, 2009 | 08:05 AM
  #993
iturregui's Avatar
Wow, I'll take a look at this. I hope it's the issue
Old Nov 9, 2009 | 08:09 AM
  #994
fostytou's Avatar
EvoM Community Team
Originally Posted by iturregui
This 3rd gear pull was done at 26psi. There is a fuel cut at 6437 RPM. The load is huge. I don't know what is going on
Code:
11.1	1	12.54	257.68	241.25
100	5031.25	13.86	75.2	5.98	-2.06	0.1	0.96	0.78	11.78	49.68	11.1	1	11.83	273.11	252.5
100	5125	13.79	75.2	5.98	-2.06	0.1	0.96	0.78	12.29	52.48	10.7	1	12.06	290.49	270.94
100	5250	13.86	75.2	5.98	-2.06	0.1	0.96	0.78	13.06	57.46	10.1	0	12.3	315.19	298.13
100	5375	13.79	75.2	5.98	-2.06	0.1	0.96	0.78	14.08	63.8	10.1	0	12.38	336.03	324.38
100	5500	13.71	75.2	5.98	-2.06	0.1	0.96	0.78	14.85	68.83	10	0	12.38	361.11	347.19
100	5656.25	13.79	75.2	5.98	-2.06	0.1	0.96	0.78	15.36	73.2	10.3	2	12.3	365.2	357.5
100	5812.5	13.64	73.4	5.98	-2.06	0.1	0.96	0.78	15.87	77.71	10.7	2	12.3	377.38	368.75
100	5968.75	13.57	73.4	5.98	-2.06	0.1	0.96	0.76	15.87	80.19	11	2	12.14	378.53	370
100	6125	13.57	73.4	5.98	-2.06	0.1	0.96	0.76	16.38	84.91	11.2	1	11.91	377.42	372.5
100	6281.25	13.57	73.4	5.98	-2.06	0.1	0.96	0.76	16.9	89.76	11.2	1	11.76	378.7	377.5
100	6437.5	13.49	73.4	5.98	-2.06	0.1	0.96	0.76	0	0	11.1	1	11.61	-11.34	365.94
100	5875	13.86	73.4	5.98	-2.06	0.1	0	0.21	6.4	37.33	18.4	1	12.3	183.43	184.69
100	6312.5	13.93	73.4	5.98	-2.06	0.1	0.04	0	1.02	5.68	18.4	0	14.04	23.38	26.88
23.92	6343.75	14.23	77	5.98	-2.06	0.1	0.88	0.66	1.79	9.66	13.9	0	14.04	45.71	46.88
23.53	6468.75	14.08	84.2	5.98	-2.06	0.1	0.06	0.7	1.79	9.61	12.3	0	13.34	56.66	37.5
i looked @ your sig and notice no fuel pump upgrade... maybe thats it...
There is probably enough time there to hit boost cut, but we can't tell because you didn't post the log timing. Check that and let us know if that is your problem (you can also just set the timer to 30000 ms).
Why are you logging loadcalc and 2 byte? Just use 1 byte and your logs will have much more resolution.
Old Nov 9, 2009 | 08:13 AM
  #995
hediki12's Avatar
kool glad i can help cant wait to get my car back and start tuning again!!
Old Nov 9, 2009 | 08:40 AM
  #996
SeanV's Avatar
Thx, I do realize the calculation is pretty simple.
What I am trying to find out, is which equations in the XML file do I need to change, so that the values in the ROM file are displayed in BAR and not PSI.
I would much prefer doing it once in the XML file, than having to do a conversion every time I want to work on the PSI boost related tables.
Lot less likely of making a mistake, as I can relate to Bar much easier at a glance, than PSI.
Old Nov 9, 2009 | 08:45 AM
  #997
tnt1106's Avatar
no one else having issues Logging fuel trims after moving From V6 to V7??
(88590715)
Old Nov 9, 2009 | 09:13 AM
  #998
iturregui's Avatar
Timing is peaking at 11 on redline. It did not give me any problems before. I don't understand why I'm hitting such high load values, as they used to be around 320's.
And about the 1 byte load.......I don't know, I have been using 2-byte load since a long time ago and did not even bother with the 1-byte one. I'll take a look at that one
Old Nov 9, 2009 | 10:10 AM
  #999
fostytou's Avatar
EvoM Community Team
As with any other table (and previously described here), you can go to "edit map definition" and see the scaling name, or just look for the table in the XML and see the scaling name directly. Then just copy that scaling to a new scaling name, change to to/from calc equations with the proper algebra, and change the tables to reference that scaling. Examples and descriptions have already peppered this thread for the omni 3 and 4 bar sensors. You will be doing basically the same thing.
I meant log timing as in "what time is it in the log". If you are hitting higher load than before you probably have a boost leak. If that is causing you to go over the boos cut feature for long enough, then kudos to it for letting you know something is wrong.
By eliminating battery, STFT,MTFT,HTFT,O2,O2_2,LdCalc (or having it reference 1 byte load if you need it for map tracer), and switching Ld2Byte to 1 byte load you should see ~43% reduction in overhead (or ~57% more resolution in your logs).
Old Nov 9, 2009 | 11:47 AM
  #1000
iturregui's Avatar
I tested for boost leaks and there are none. I just took off the electronic boost controller and installed a manual one and it seems to be better. I'll log it later today and post the results
Old Nov 9, 2009 | 01:06 PM
  #1001
lan_evo_mr9's Avatar
(88590715)
Nope.
Old Nov 9, 2009 | 06:26 PM
  #1002
adammartini's Avatar
so you cant use ecuflash 1.42 with an OpenPort 1.3? but the open port 2.0 is for the evo x?
if i got ecuflsh 1.39 and got a opnport 1.3_ would I be able to use the tehramod shiuld i just start off it thehamod 5? would i even be able to use 5 with the two 1.3s?
Old Nov 9, 2009 | 08:11 PM
  #1003
Evo_Jay's Avatar
you can use openport 1.3 with any version of ecuflash.
Old Nov 9, 2009 | 08:36 PM
  #1004
jba3's Avatar
I have ECUFlash 1.42 with an OpenPort 1.3 cable, no issues reading or reflashing an 03, with windows 7 ultimate 32 bit.
Old Nov 9, 2009 | 11:29 PM
  #1005
project_skyline's Avatar
I give up asking questions in here anymore. So far I've made 4 inquiries and somehow nothing gets answered yet everyone else get a response.
Quick Reply: TephraMod V7
