TephraMod V7
#1022
hey all,
been real busy so i have only managed to test the v7 on my car this week..
I used to run a 88840016 rom, using the 88590715 plus mods now.
my car idles great and seems to drive perfect, BUT
I cannot get the car to start without disabling the immobiliser, the immobiliser code is correct, the immob hex i have tried them all, and on my previous rom i cannot see this code on ecuflash, so not sure what it was.... any thoughts anyone?
ALso i seem to be getting an error on my car, the codes are
P0462Fuel level sensor circuit low input
p0441 - *cannot find the error*
p0107 Pressure sensor circuit low input
p0446 - Evap system vent control
I was not getting these before, how to I deactivate them or correct them?
otherwise i am a happy camper.. thanks guys... donation sent a while ago.
Mike
Mike
#1024
Mike
FCA bit13 for p0441
bit15 for p0446
FDA bit 11 for p0461
Id check periphery bits for both roms and set them to the same as original rom see how it goes from there
#1025
Hi
thanks for that, the error codes are gone now.
just immob and one more issue i noticed.
my timing values in the upper load sites (110+) are a good 3-5 degrees morethan the ign map!!!! and it doesn't seem to be constant... i need to search, will post back if i find nothing.
Mike
Mike
#1026
hey all,
Mike
Mike
#1027
Have you made sure that not only the immobilizer code itself, but also the memory address location in flash where the immobilizer code is actually stored are both correct?
#1028
TPS WGDC Correction
I have a problem with oscilating boost under part throttle if i set the right side of TPS WGDC Correction table to anything lower than 100%.
For example: I put 90% wgdc in my Base WGDC table, and 50% at 50% throttle in my TPS WGDC correction. When I hold the pedal at half-throttle at first I have what I expect to - 45% WGDC and lower boost... ...than a moment later my WGDC get back to 90% and almost full boost! Half a second later situation repeats - WGDC is lowered to 45% and boost is lowered too, than its back to my 90% from Base WGDC table and almost full boost!
So it seems like TBEC routine works against TPS WGDC Correction function!
Did anybody have any success applying TPS WGDC Correction?
Anybody?
#1029
With the MBC installed the car is running LEAN up top, with IDC's hitting 116% !!!
It's still hitting load values around 370....Don't know why, as there are no boost leaks. I'm reading the boost with two different gauges, with independent lines, so I don't think I'm overboosting and reading it wrong. I'm gonna take the turbo off today to inspect the turbine wheel.
And props to hediki12, as I was hitting boost cut and didn't realize it!!
I wonder who put that there
#1031
biggy , I don't think this is of any help, but here are my settings. I'm actually using psi based boost control. Ignore the over 100 in the wgdc map, its for the effect.
#1032
0x006C for those of you wondering. i thought we had the aus rom, but i am not sure, def not edm for the evo 9, but edm works on the 8's.
mine works now.
Mike
#1033
do you have any issues like oscilating boost under 50% throttle conditions? is your TBEC on? what do you have in "Max Upward WGDC Corr" table?
#1034
mwdc/tps from 75 up 1,2,3
but have had no problems with boost oscillations, other than when my gear / rpm was off.
doubt any of this is important, I'd look at some other factor.
maybe "afr out of range" or something similar that you have inadvertently OKed.
#1035
1 question to Tephra: Does TBEC work when TPS WGDC Correction multiplier is applied?
