TephraMod V7
Old Nov 25, 2009 | 08:11 AM
  #1111
fostytou's Avatar
EvoM Community Team
Originally Posted by Brad74
V7 is perfect for me, rom 88580714, original rom 88840016... Very good job Tephra...
Donation sent.
A question, how could I log Mivec, as MUT40 and MUT41 are used for 1byte gear
1byte load..
I'm not using boost control in the ECU because I have an AVCR, thanks for your answer
Paste the MUT values into those MUT locations from a rom where they were logged properly.
Old Nov 25, 2009 | 08:25 AM
  #1112
Brad74's Avatar
Thanks for your answer, I've actually never log my mivec... You mean I have to use 0x7650 and 0x7651 in MUT40 and MUT41? I m using 1Byte load, I forgot to specify it in my first post.
Old Nov 25, 2009 | 03:40 PM
  #1113
ziad's Avatar
i think someone posted before that below 25deg temp, the temp compensated load was used and over 25deg baro+temp compensated load was used in ign and fuel. thats from the MAF sensor.
Old Nov 25, 2009 | 03:48 PM
  #1114
l2r99gst's Avatar
Here is info from mrfred that I had saved in my notes:
spark advance lookup: For air temp below 77F, baro+airtemp compensated load is used for spark advance. For temps above 77F, then baro compensated load is used.
afr lookup: for closed loop conditions when load is < ~20, uncompensated load is used, otherwise, baro+airtemp compensated load is used. This means that baro+airtemp compensated load is used essentially all the time for AFR lookup.
Old Nov 26, 2009 | 12:17 AM
  #1115
Boosted GP's Avatar
Originally Posted by daymean
I am using load based as well...so the 2byte load + baro is the most accurate load for you?
I am on 96260009 and I am using 2 byte load with 8984 and 8985 as the mut 00 and mut 01 addresses. I believe that this is 2byte load raw...will try 2byte load baro and temp...
what loads are u using to put in your BDEL tables - the loads gained from 2byte load + baro?
havent got to bdel as i am still tuning and dont want these other table skewing the results of the log and messing me around.
Mike
Old Nov 26, 2009 | 07:25 AM
  #1116
Jim in Tucson's Avatar
Originally Posted by ziad
guys for 96532706 (ie the Livemap version) the defs for the "Injector Cranking enrichment IPW Adder (Main)" are wrong. they need to be 0x58d0 and the axis is 0x69d8 and 9 elements.
i presume the other xmls will be wrong too.
Thanks for posting this ziad. BTW, I'm using the basic 96530706 ROM. I first noticed this a few weeks ago, but I did not know the solution until now. Been struggling all this time trying to get the car to start in cool/cold weather.
Much appreciated.
Old Nov 26, 2009 | 07:44 AM
  #1117
donour's Avatar
Exactly. As several others have noted, load_raw/1byte load can be way, way off baro+temp compensated values -- as much as 30%.
d
Old Nov 26, 2009 | 07:59 AM
  #1118
daymean's Avatar
^^^ so i am guessing that you guys generally use 2byte baro+temp to tell what cells the car is accessing?
Old Nov 26, 2009 | 08:49 AM
  #1119
evonut270's Avatar
any news on the other roms yet?
Old Nov 26, 2009 | 10:07 AM
  #1120
donour's Avatar
Exactly. I'm using 96530706.
d
Old Nov 26, 2009 | 10:41 AM
  #1121
SeanV's Avatar
Yup, using exactly that on my 96530706 and it is spot on.
Still need to try just Baro, but since the Temp and Baro work perfectly for me, there is no point really.
Using the RAW values at my high altitude skews the load cells quite a bit.
Old Nov 26, 2009 | 11:30 AM
  #1122
daymean's Avatar
^^ Thanks man, guess i will test and see what works best for me!
Old Nov 28, 2009 | 07:49 PM
  #1123
supersnow's Avatar
I have a little problem; on my v6 (88590615) the boost is set up to hit 28 psi. When I use v7, it can't go past 20 psi plus is very laggy. I'm using direct boost control with gm three port; like i said.....on my v6 it works flawless. Actually, the WGDC goes to 33 and stay at 33 for the entire run. Thanks for the help!
Old Nov 29, 2009 | 01:00 AM
  #1124
fostytou's Avatar
EvoM Community Team
Sounds like you did your direct boost control mod wrong. Revisit it and report back...
Old Nov 29, 2009 | 11:31 AM
  #1125
supersnow's Avatar
I will verify again but I'm pretty sure all the tables were copy from the v6 to the v7. The only difference was I had drop boost at high knock enable on v7...........there was no knock on the run btw.
Quick Reply: TephraMod V7
