TephraMod V7
#1176
Hmm...Is it thowing any codes? Unless you wanna turn off the immobilizer altogether using the FAA periphery at bit 2. Set it to 1 and try again. Also, using the xml I supplied earlier, there should be an ECU periphery 7 table available. What does the 0xffa line read?
#1177
I turned off the immobilizer and it started right up now i just need to work on the maps. The stationary rev limiter isnt working? I set it at 3500 and turned on the launch maps but its not limiting it to 3500.
#1178
Are you guys using my XML that JoT made? In that XML it clearly defines for each year what you need to set the immob. hex to, like this:
0x0040 for 2003 or 0x0055 for 2004 or 0x0058 for 2005 USDM - 0x004D for EDM
#1179
I'm not familiar with the Eclipses, but does yours have both resting and depressed clutch switches?
#1180
Hey Phenem, I gave him recompiles version that I modified slightly. I think its recompile's version at least, because I can't find the original link. (its buried within the past 1000 posts)
#1185
