TephraMod V7
#1187
I guess it could be that evos have 2 clutch sensors and eclipses dont? so how would i turn off the need for the sensors for the rev limiter to work? The stationary rev limiter worked fine on the 94170008, IDK?
#1188
For the immobilizer: That first line in the periphery 7 (0xffa) should read one of the immobilizer hexes previously mentioned (0040,0055,0058) . I'd use that to double check the change made to the immobilizer hex.
#1192
i have an 2006 evo IX edm version that uses the immob hex 006C.
Mike
#1194
Anyone else having problems with the Stationary Rev-Limiter? I switched back to 94170008 and it still works on that rom so its not the sensor, has to be something with the 96530706 rom. Any Ideas?
#1197
I noticed you have lean spool disabled by setting it's rpm values to = 0. Rather than doing it that way set them to stock and disable periphery FBA bit 0. Set it to = 0.
Lean spool may have something to do with your launch map not working right.
#1198
I just setup 88590715 on my EVO IX and am getting a code:
P0037 - Heated oxygen sensor (rear) heater circuit low
I am running a wideband o2 sensor to the rear o2 sensor input, and have the rear o2 simulator enabled in the Tephra options.
Anyone run into this before? I was running the same physical setup with 5.10 (rear o2 simulator, OBD inspection pass mods) and never got a CEL.
#1199
Make sure you have 0009 in the Rear 02 heater patch
Disable periphery FAA bit 1.
