TephraMod V7
Old Feb 14, 2010 | 11:53 PM
  #1441
tephra's Avatar
can you (i didn't ask already did I??) take a picture of the snafu and post it?
Old Feb 15, 2010 | 12:02 AM
  #1442
nonschlont's Avatar
Heres the 1/2 MUT table...
Old Feb 15, 2010 | 12:06 AM
  #1443
tephra's Avatar
looks ok to me?
Old Feb 15, 2010 | 12:10 AM
  #1444
nonschlont's Avatar
looks ok to me?
lol... isnt there the bottom 1/2 of the table missing, and the FFFF's as well... I think I read somewhere theres a "newer" MUT table w/out the FFFF's, but never saw it... I take it this is it? Theres nothing missing from this? Seems like there were quite a few missing request ID's...
edit: this is what Im used to seeing...
Old Feb 15, 2010 | 12:14 AM
  #1445
tephra's Avatar
OOOOOOOOOOH
ok
the first one you posted has a different XML that removes the leading 0xFFFF's, it shouldn't be anything to worry about...
also dont worry that it only goes upto MUTFX, you cant really do anything with higher than MUT90 anyways...
Old Feb 15, 2010 | 12:24 AM
  #1446
nonschlont's Avatar
OOOOOOOOOOH
ok
Ive been goin at it for a couple hours, the last couple nights, chasing my tail, trying to figure this out...
good to know. Thanks for the insight!
Looks like v.7 here I come. again...
Old Feb 15, 2010 | 01:17 PM
  #1447
03lances's Avatar
Ok so this has probably answered severaly times but i just wanna be clear, in ecuflash where its says "STOCK REPLACEMENT MAPS BELOW" the fuel and timing maps directly below this are my main maps I want to paste my tables in correct?
Old Feb 15, 2010 | 01:43 PM
  #1448
travman's Avatar
Yes they are your main fuel & timing maps
Old Feb 15, 2010 | 03:22 PM
  #1449
kaj's Avatar
kaj
can anyone list what problems have yet to be fixed? i'd LOVE to read through all 100pgs (lol)... but i just don't have that kinda time.
i'd like to try v7 again 'cause i like the higher-res maps (though i can't view the 3-d graph and maps at the same time), but i had nothing but trouble with v7.
i haven't tried v7 since December.. assuming most bugs have been worked out? so far i'm still on v5.. not so sure i really need v7.
advice, anyone?
Old Feb 15, 2010 | 03:24 PM
  #1450
03lances's Avatar
Cool thank you
Old Feb 15, 2010 | 03:54 PM
  #1451
03lances's Avatar
Ok so one last noob question, in the tephra mod option table, to turn these on and off is it 0=off and 1=on? I ask because in my table the rear 02 sim is checked at 1 and so if this means its enabled, I still have my rear 02 and so I dont want this enabled
Old Feb 15, 2010 | 04:10 PM
  #1452
Jack_of_Trades's Avatar
You got it. If the Rear O2 Simulator is 1, it's enabled. So you're ECU isn't using the signal from the Rear O2, it's using the simulated signal.
Old Feb 15, 2010 | 05:10 PM
  #1453
nonschlont's Avatar
ive got another newb question...
Im now trying to understand why I have a set of "small" timing maps (all 3HOT) which I need to copy my original maps to, and shows under "timing", and not something properly labeled like everything else... And, also I have no small map for fuel.
Im assuming I would need both being shown, right?
Is this another case of the .xmls getting corrupted? It doesnt seem to have, like the other...
Old Feb 15, 2010 | 06:28 PM
  #1454
Jim in Tucson's Avatar
Bizarre! You are running ROM 9653 v7 correct? I see nothing like that in my ROM. I see ALT MAP and MAIN MAP. Just like the list posted here.
Can you post a pic of where you are reading this?
Old Feb 15, 2010 | 06:41 PM
  #1455
03lances's Avatar
No I am running a 941xx ROM at the moment but this might change tomorrow
Quick Reply: TephraMod V7
