new live map app
#631
Is anyone having an error about "the beta has ended"? I am using the version 0.504 and I found where ziad said there was no more beta...
EDIT: I tried my old laptop that was working a few months ago and it has the same beta error. I rolled the clock back on my new install and it passed the "beta" test and ran. Looks like the "beta" was not removed but just bumped to 2022. Bummer...
Edit2: Maybe there's a later version that 0.504 but I can't find it so we may be SOL.
Edit3: I scoured my Google drive backups and found my old XP laptop I had in 2014/2015 and the newest install I found was setup0504.exe, like Raptord sent me and a few other a few years back.
EDIT4: Apparently Ziad didn't obfuscate the exe...so I found in the binary that the end beta date appears to be 1/1/2022 for 0.504. Not sure at this point what to do from here.
#632
#634
I will give it a try tonight when I get home.
#635
https://github.com/DowJhob/Evo-live-...ses/tag/1.007d
more update, for fast logg
dingus (Jan 8, 2022)
#639
#640
Bit off topic.
I run the 96262709 rom and with Dow Jhob we are working on the live map client with Open Port 2.0. Feel free to connect on his discord channel to test and report if you're interested.
Also Do you run psi based ecu boost? I got a decently complete xml from Hyperdisorder for this, but cannot seem to enabled psi based boost for some reason
#641
Thank you so much for the reply,
I have visited the link provided above but I have not spotted any guide on how to get it up and running. I am running 9626709 Tephra v7, but I am not sure if there is modification needed to that rom or anything apart from connecting to the car and launching the windows software. Sorry if the questions are quite basic but its something I haven't have done before.
finally I am not running psi based ECU boost but I am more than willing to have a look on your rom or whatever you have done and feedback to you. I am sure you have my contact details, so let me know
#642
Sent you a PM
#643
Thanks for the rolling back the date trick for getting ELM to pass the beta check. I just reflashed today to adjust the cranking enrichment, because it is fairly cold here and then I couldn't get ELM open to reset dead.
Bster13
May 22, 2009 07:44 PM
app, apps, dmalivemap, evo, evolivemap, evolutionm, live, livemap, map, reading, register, tephramod, traceevoscan, zedgraphdll, ziads
